I Have A Fresh Water Spring In The Basement That Is Leaking, How Can I Contol It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 08:02 AM   #1
Is there a way to cap the spring an use the water? There is a large systern in the basement as well
z5600 is offline   Reply With Quote
Old 06-23-2010, 06:51 PM   #2
Rewards Points: 1,512
It is usually hard to cap a spring because it will break through the ground somewhere else nearby.
You could install a holding tank (cistern) to hold some of the water and when that fills up you "waste" the rest of the water down some hill outside.
To alleviate leaking into the basement the best bet is a perimeter drain system leading to a sump pump pit (or the cistern if below floor level).
Old 06-24-2010, 06:42 PM   #3
Rewards Points: 1,092
wow!
Free water? Lucky guy. Any well drillers around there that could give you advice on how to tap into it and perhaps divert at least some of it away from the house? Seems there should be an easy way (yeah, right. REAL easy....) to get a pipe into it and draw it in a more controlled manner. Let us know if you find anything out. Thanks. j
Old 06-24-2010, 08:01 PM   #4
Rewards Points: 276
I'm not sure you'd want to drink it without testing it or treating it. The large commercial spring water distributors like Poland Spring ozonate the water first. That sanitizes it without adding that chlorine flavor but it then needs to sit in an open tank for 24 hours to evaporate the ozone because it's poisonous.
Jim F is offline   Reply With Quote
Old 06-24-2010, 08:39 PM   #5
Rewards Points: 1,910
Any pictures?
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 02:48 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Not sure which forum, but Driveway Expansion Joints Leaking into Basement, help? ClemsonJeeper Concrete, Stone & Masonry 2 08-07-2009 11:42 AM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 08:20 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
