I Freakin Hate Vinyl Siding ! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 01:49 PM   #16
Rewards Points: 1,062
Question
Originally Posted by Ron6519 View Post
To install the wood siding you will need to install a proper nailing surface. The question is, do you have the clearance to do this? Typically siding nails are 2" for proper holding of the 3/4" siding. That would mean installing 2x 4 thick material to hold the siding to the wall. Seems like alot of effort for a temporary fix.
Ron
wood siding will be permanent. what kind of nailing surface should i have and how should i attach it to cement walls ?
thanks.
Old 12-22-2008, 02:03 PM   #17
Rewards Points: 5,336
I'd use 2x4's, laid flat on the concrete. Attached with tapcon screws and construction adhesive. I would build a perimiter frame and install the flat 2x4's 16 " on center in the middle.
Ron
Old 12-22-2008, 02:13 PM   #18
Ron
i have done something quite similar in the recent past with 3/8 x 6 bolts going in pre-drilled holes in concrete/brick through pre-drilled holes in PT 2x4s. filled holes in the wall with 2-part anchoring epoxy and then set bolts in. ROCK SOLID !! that anchoring epoxy is some crazy stuff !
Old 12-22-2008, 05:22 PM   #19
Ron6519 - do you think it will be OK to nail the 1x8 planks to vertical 2x4s using a regular trim nailer (1.5 in, i believe) ? also, do you think the 2x4 should be PT ?
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
