I Can't Remove Exterior Door Knob, No Screws, How To Remove? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 02:37 PM   #1
I can't remove exterior door knob, no screws, how to remove?
So here is my door knob, I can't figure out how to remove it, how would I do it?
kata is offline   Reply With Quote
Old 11-01-2011, 03:13 PM   #2
DIY staff
Rewards Points: 7,174
Usually the outside knob comes off by unscrewing the INSIDE plate off.
On older knobs--you push in a button on the shaft of the inside knob using a screw driver---
Looks like that knob might have the slot--
then pry off the escutcheon by the door and a set of screws will be under it---
Old 11-01-2011, 03:24 PM   #3
Maintenance
Just like Mike said.
Steven B is offline   Reply With Quote
Old 11-01-2011, 03:48 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
mike is correct, sometimes though teh button is really small and you will need a small allen key to get at it instead of a botton..
some other really old door knobs actually will twist off
woodworkbykirk is offline   Reply With Quote
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 04:05 PM
Cant remove old door knob...? toicy4ya Carpentry 11 09-06-2011 06:52 PM
Metal Roof Screws Leaking WBNC Roofing/Siding 14 01-24-2010 03:50 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
