Old 04-13-2009, 12:20 AM   #1
Default i beam strength
i need to know is it stronger to weld to i beam side by side or weld channel iron to each side of one i beam as i need to move a house
larry pederson is offline   Reply With Quote
Old 04-13-2009, 01:40 AM   #2
Structural Engineer
Completely depends on the size of the sections you are considering, what specific type of steel they are made of, and what the weld detail is.
But, my gut says a wide flange shape (i-beam) with a channel on each side would be stronger. Due to the fact that all elements (flange or web) would be considered "stiffened" according to the AISC, reducing the chances of local buckling.
wildcat is offline   Reply With Quote
Old 04-13-2009, 11:37 PM   #3
Default i beam
i thank you for your educated gut feeling. the beams are going to be 75 ft. ill be lifting on the beams about 65 ft. apart . i would like to use
32# 12 inch i beam and of course 3by 12 inch channel iron. i dont know if it should be welded solid all the way or space the weld.got any idea on this.any opinion on these ideas are greatly apprecited.
Old 04-13-2009, 11:43 PM   #4
Civil Engineer
Truly you are a brave man, the average person getting ready to move a house would consult with a structural engineer regarding the required size, spacing, and stiffening of the beams, and would want a specific procedure for moving the house. Please let us know how your move goes.
Old 04-14-2009, 02:39 AM   #5
Structural Engineer
This is a tremendous idea. If something were to go wrong and someone gets a minor injury you will be in deep, deep crap if you didn't consult with a structural engineer.
The house could potentially be uninsurable if something goes wrong with it and an engineer has not be consulted.
Old 04-14-2009, 03:19 AM   #6
what would the insurance company need before they approve a claim?
fast1 is offline   Reply With Quote
Old 04-14-2009, 09:34 AM   #7
Structural Engineer
Well, if a professional contractor (house mover) is doing the work, then that contractor is bonded and insured to do such tasks.
If you're doing something like this on your own, I would assume you would need to check your homeowners policy to see if it would even cover this. It would make sense that an insurance company require a professional to handle such a task. Insurance policies vary widely, so you would need to check with your agent or policy issuer on the specifics. I'm just assuming this is a potential problem based on the fact that some insurance companies require proof of building permits for work done to homes, or they won't insure.
More On This Topic
I'm Romie Brown. On behalf of Expert Village, I'm here to discuss with you tips and tidbits on how to buy homeowner's insurance. In this clip, we're going to talk about keeping your insurance up to date. In previous clips, we discussed, getting your... Read More »
I'm Ronnie Brown on behalf of Expert Village I'm here to discuss with you tips and tidbits on how to buy homeowners insurance. In this clip we?re going to talk about what is in a standard homeowner?s policy. There's like four components. The first... Read More »
How to Get Title Insurance
How to Get Title Insurance by Expert Village
Hi, I'm John Jackson from Remax Suburban in St. Louis, Missouri. I'm here today to talk about how to buy a house for Expert Village. Here in Missouri, title companies act as settlement agents. And I do know that around the United States and in Canada... Read More »
Builder's risk insurance is a temporary type of property insurance for homeowners that are renovating their homes or adding on to them and construction companies and general contractors who are building new structures. Policies vary depending on the... Read More »
Tornados are natural disasters that can strike anytime. Having the proper insurance is essential when a tornado damages your home and personal property. Insurance gives you a sense of security from any damage that a tornado may cause. Don't wait for a... Read More »
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 06:24 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 10:46 PM
Ridge Beam Height/Rafter Length JohnRussell Roofing 0 05-14-2008 03:27 PM
Remove Load Bearing Wall Beneath Hanging Beam cnaildrivenail Remodeling 0 04-29-2008 01:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
