Old 01-31-2009, 08:49 AM   #1
I-Beam For Joist To Avoid Support Post
Constructing a 20x30 shop and planning on 2 story.My question is can I use two 20ft steel i-beams(12"high and 5/16 thick)to support 2x6x10s on 16" centers for flooring.Not planning on storing anything real heavy up stairs.Tried using formulas and calcs. but I didn't fully understand them.Thanks!
we3861 is offline   Reply With Quote
Old 01-31-2009, 10:53 AM   #2
Moderator
Termite's Avatar
You need a structural engineer to take a look at your design to make sure that the beams you propose using will work. The tributary load on those beams would be pretty high, and I seriously doubt you'll get a 12" beam to span 30'.
Old 01-31-2009, 10:58 AM   #3
joed's Avatar
The beam only needs to span 20'.
Old 01-31-2009, 12:47 PM   #4
Thumbs up
Yes the ibeams will cross the 20ft span and divide the upper floor(lower roof) into three 10ft sections.The ibeams running in the "Y" axis and 2x6x10's running in the "X" axis with 3/4 plywood tying everything in together.Thanks for all your help. Think this will be sufficient or do I need to regroup?
Old 01-31-2009, 02:40 PM   #5
Moderator
Termite's Avatar
Either way you'll need an engineer or architect to sign off. You won't be able to get a building permit in most jurisdictions without the support/seal of a design professional.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
