Hydronic Radiant Heat And Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 10:00 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
Hydronic radiant heat and joists
I'm planing out a possible DIY radiant heat installation and I am wondering, if I make 1/2" holes or so through every single joist at a few locations, would this pose a significant structural issue? The joists are 2x8 and span about 12 feet. These holes would be rather high up.
I may make the tubing just go around the joists to avoid making all these holes, but if I make holes it will make for a neater install. The water pipes would run parallel with the joists so the only area that would have holes is on both ends of each joist, to get to the next joist. I still don't feel comfortable making this many holes, unless someone can say I'm completely safe.
Old 01-14-2011, 11:26 AM   #2
Rewards Points: 150
As long as A)the hole diameter is less than 1/3 the width of the joist, and you stick to the distal 1/3 of the joist, you will be fine.
gbwillner is offline   Reply With Quote
Old 01-14-2011, 11:39 AM   #3
12' span on 2x8 sounds pretty maxed out. Are you tiling above or just adding heat?
The older I get the better I was
Old 01-14-2011, 04:01 PM   #4
Wire Chewer
Rewards Points: 54
Just adding heat, already tiled (one side is tiled, other is just hardwood). In fact there are some cracks in the grout, so that probably indicates some slight movement already.
radiant heat questions mazzonetv Plumbing 0 10-04-2010 04:49 PM
electric radiant floor heat w36cowgirl HVAC 6 03-31-2010 02:25 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 07:28 PM
Questionable radiant heat installation jzinckgra HVAC 3 05-30-2008 08:55 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
