Hydrolic Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2014, 11:25 PM   #1
Rewards Points: 4
Hydrolic concrete
Hi all,
We are doing hydrolic concrete as canal, tuynel... designer use ACI code system. But the audit come and ask me for the antileakge test for concrete. I dont know in the ACI code where address to this problem. Pls help me to respond this problem, thanks!
giangvqpp is offline   Reply With Quote
Old 11-21-2014, 05:13 PM   #2
Rewards Points: 4,526
under what circumstances would anyone use hydraulic cement in either canal OR tunnel ? we were always spec'd to use polyurethane hydrophyllic/hydrophobic injection grout even going back to the lincoln & holland tunnels + world trade center work,,, perhaps specs have changed OR your ' audit ' is not aware of something,,, where's this job located - usa OR ? ? ?
Old 11-21-2014, 08:06 PM   #3
Rewards Points: 4
I am in Vietnam, the structure under water. We use cement type V (ASTM C150). Our problem is antileakage testing. Sorry hydraulic concrete not hydrolic
Old 11-21-2014, 10:50 PM   #4
Rewards Points: 392
You might want to try joining the engineering forum related to that and ask that question there.
http://www.eng-tips.com
Good luck
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
giangvqpp (11-22-2014)
Old 11-22-2014, 12:22 PM   #5
Rewards Points: 3,398
Type v cement is primarily used for a sulfate resistant concrete, and pouring underwater you should be using a tremie, or if not a cofferdam would be a much easier way to go.
Canarywood1 is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
