Old 01-14-2009, 06:24 PM   #1
Hybrid Deck - Is Pressure Treated + Composite Feasible?
Completely new to building decks here.
Is it possible to build a deck out of both pressure treated wood and composite material?
What I have envisioned is a pressure treated base/beams using the expensive composite pieces only where you can actually see them.
Is this even possible? Or is this how they are normally built?
Is there a good online calculator I can use to estimate how much the materials will cost?
kyassassin is offline   Reply With Quote
Old 01-14-2009, 08:58 PM   #2
Remodeling Contractor
Decks are always built with pressure treated lumber as the frame. (joists and posts and stair stringers) this is code. Better decks will have the composites used for the decking and even the railings. Deck materials with composites will cost about $10-12.50 Sq/st Railings can range from $50 -350 ln/ft Labor. average deck of 250 sq ft will take two men 4 days to complete. One for layout and pillars one for framing one for decking one for trim and railings ,stairs and skirting.
Old 01-14-2009, 09:03 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, done all the time.
That is how it is done.
Framework is constructed out of Pressure Treated Lumber. Deck boards and railings can be composite.
As stated, Yes = standard construction method.
I think there may be....? Try doing a search
- Build Well -
Old 01-15-2009, 07:19 AM   #4
Man of many hats
wrangler's Avatar
You can also go to Lowes and they can build your deck on a program similar to autocad that will also give you a shopping list and pricing.
Man of many hats
wrangler is offline   Reply With Quote
Old 01-15-2009, 09:33 PM   #5
you can actually get the specs from your local lowes commercial sales for free
tradewinds is offline   Reply With Quote
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 12:24 PM
pressure treated deck problem julie708 General Discussion 2 10-01-2008 06:46 PM
How do you tell the diff btw Pressure treated and regular hardwood zhbuyi Carpentry 3 06-08-2008 08:11 PM
Composite Deck penaddict Building & Construction 7 03-17-2006 11:35 PM
