HVAC Duct Through A Fire Rated Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 12:58 AM   #1
Rewards Points: 137
HVAC duct through a fire rated wall
I converted the rear section of the garage into a laundry room with a wall newly constructed to divide the laundry from the rest of the garage. This wall needs to be a fire rated wall. I am required to put HVAC register in the laundry since it will be considered habitable space. The air handler is in the garage very close to this wall. It would be a simple matter to run a duct from the air handler through this wall into the laundry. Can I put the duct through the wall and still maintain the fire rating? Any suggestions what I would do if I cannot put a duct through this wall?
elmaur is offline   Reply With Quote
Old 05-30-2011, 07:05 AM   #2
Rewards Points: 5,336
Have you contacted your local building dept? They should be able to guide you so as to comply with the local regulations.
Update your profile and put in a locale.
Ron
Old 05-30-2011, 12:22 PM   #3
Rewards Points: 137
When I submitted my plans as the homeowner for a building permit indicating the HVAC duct through this wall the only comment the examiner made was that the duct had to be 26 gauge with R8 insulation. I think it is possible he overlooked the issue of the fire rating. I will contact him tomorrow. I think he is out barbecuing today.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
How to frame door under hvac duct cai Building & Construction 5 06-15-2010 07:05 PM
adding foam bd insulation to attic wall (fire code) park9472 Building & Construction 0 04-14-2010 02:17 PM
Running duct over bearing wall jhillman HVAC 10 03-23-2009 02:54 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
