-   -   HVAC duct through a fire rated wall (http://www.diychatroom.com/f19/hvac-duct-through-fire-rated-wall-105974/)
elmaur 05-30-2011 01:58 AM
I converted the rear section of the garage into a laundry room with a wall newly constructed to divide the laundry from the rest of the garage. This wall needs to be a fire rated wall. I am required to put HVAC register in the laundry since it will be considered habitable space. The air handler is in the garage very close to this wall. It would be a simple matter to run a duct from the air handler through this wall into the laundry. Can I put the duct through the wall and still maintain the fire rating? Any suggestions what I would do if I cannot put a duct through this wall?
Ron6519 05-30-2011 08:05 AM
Have you contacted your local building dept? They should be able to guide you so as to comply with the local regulations.
Update your profile and put in a locale.
Ron
elmaur 05-30-2011 01:22 PM
When I submitted my plans as the homeowner for a building permit indicating the HVAC duct through this wall the only comment the examiner made was that the duct had to be 26 gauge with R8 insulation. I think it is possible he overlooked the issue of the fire rating. I will contact him tomorrow. I think he is out barbecuing today.
