HVAC Ceiling Vent Falling Off, How To Fix? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 04:01 PM   #1
HVAC Ceiling vent falling off, how to fix?
Hello, I'm not sure if this is the correct forum for my post so please bear with me. It's not a real HVAC issue per se.
Our home has central air and one of the rooms has a loose ceiling vent. The drywall has broken away on both edges giving the vent screws nothing to secure to. How can I repair this? I've gone all McGyver on it and tried using paper clips to secure custom-made strips of drywall which I can then screw the vent into, but this is not working beyond a few days. Should I cut a much large hole and replace with a bigger sheet of drywall.
Ideas?
Thanks a bunch.
guile is offline   Reply With Quote
Old 01-19-2009, 04:15 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,...
I'd probably go with longer screws,+ some sorta Wood backer.....
Old 01-19-2009, 04:17 PM   #3
Remodeling Contractor
Vents are typically secured into a sheet metal flange that sits above the sheet rock. You just need to use a 3" sheet metal screw to attach it. If there is nothing but empty space above the edges of the vent, you will need to fill with drywall or plaster first, since "sky screws" do not exist.
Old 01-19-2009, 04:34 PM   #4
Great ideas
Thanks for the ideas guys. I'll work on those sky screws some other day.
Old 01-20-2009, 02:44 PM   #5
Drywall contractor
Rewards Points: 1,070
Fastening to the drywall isn't going to hold anything for long. If your vents are in the ceiling, I assume you have attic access. Put a block of wood on either side of the "boot" to fasten the grill to if there isn't a metal flange as mentioned above.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Condensation from Ceiling AC Vent meth HVAC 29 12-15-2013 11:02 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Ceiling bits are falling off!! infection0 Building & Construction 4 09-15-2008 05:00 AM
