Hurricane Brackets (truss Brackets) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 09:33 PM   #1
Rewards Points: 502
Hurricane Brackets (truss brackets)
I am finishing up my pole barn and one of the last things I have to do before the next inspection is to install the hurricane brackets between each truss and the wall header.
Each of these brackets has slots for 10 nails. Do I really have to put 10 nails in each bracket to pass inspection?
One of the challenges is that on each truss where it lines up, is where the metal fasteners they used to join the 2x4s together is, so I have to predrill 5 holes. I have 24 trusses, so 48 brackets and 480 nails.....
It sure seems like a major overkill.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 04-03-2009, 10:06 PM   #2
If you only needed 2 nails they would have only put 2 holes in the straps.
hayewe farm is offline   Reply With Quote
Old 04-04-2009, 05:24 PM   #3
Registered User
Rewards Points: 5,244
At Simpson, you can use the H-clip instead. But, I use a pair of locking pliers clamped on a masonry nail, to tap a start hole in each gusset plate hole needed.
http://www.strongtie.com/products/CFS/H-Hybrid.asp If you have air, a $50 palm nailer works well. Be safe, GBAR
Old 04-04-2009, 06:29 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
Rent/buy a palm nailer and save yourself a buttload of time and effort.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-06-2009, 02:23 AM   #5
Rewards Points: 150
Most of the time your nails will line up with the slots in the gusset plates but if not a pair of pliers to hold the nail will save your fingers. The h-clips GBAR suggested are I think easier to work with and they can be installed from the inside also, which might help out by missing the gusset plate. And make sure you use the right nails. I've seen people use roofing nails, No good. and as far as the palm nailer suggestions, Not only will it save time but it will save your arms and wrist from unneeded pain.
James Con is offline   Reply With Quote
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 01:08 PM
Hurricane clips... is this ok? TravisT Building & Construction 5 12-24-2007 05:41 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 08:36 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
