-   -   The huge water in basement epic picture thread. Money has run out, water hasn't. (http://www.diychatroom.com/f19/huge-water-basement-epic-picture-thread-money-has-run-out-water-hasnt-107793/)
coderguy 06-15-2011 09:45 PM
Hello!
I've asked about parts of this before; and you can see my house in the "526 Lincoln House" thread in the showcase. I've posted in many threads and even sent some personal messages for help. I've done a ton of work and we have spent the rest of our money. So, instead of asking questions in other threads/etc; I've decided to post all the related pictures to give everyone a full picture of the problem and hopefully will get some help getting to the bottom of this (and I will get to the bottom of this).
The problem: Water is coming in through the first and second step of our basement "bilco" stairway. We had an interior drain tile system installed; and the water hasn't drained away from the foundation. We got a new sump pump/etc. The water started months ago; and runs 24 hours a day. Recently I half-drilled two weep holes in the side, and water runs constantly from them. Below is a full picture of the situation; I will reply to this post if I run out of picture room. I know that people have said it is just water form the window well; but wouldn't that eventually drain away? Especially if they drilled weep holes when they installed the drain tile? (They were supposed to?!?!)
1) I have diggers hotline marking the property in the next couple of days; hoping for a water line, but doesn't sound like it...
2) I've made some of the grading corrections and I'm adding gutters to the garage this weekend. The progress is all at the front of the house; which doesn't have a problem anyway.
When replying please remember that I am willing to rip everything out at this point. The 3-seasons room, bilco; whatever.
Picture from when it started:
https://lh5.googleusercontent.com/-b...0/100_0434.JPG
Picture taken tonight (sorry to take it tonight; the one I took with the rest is missing...):
http://img838.imageshack.us/img838/6282/1010578.jpg
http://img828.imageshack.us/img828/628/1010548.jpg
http://img215.imageshack.us/img215/9295/1010550x.jpg
http://img232.imageshack.us/img232/6452/1010556.jpg
http://img593.imageshack.us/img593/9067/1010557p.jpg
http://img820.imageshack.us/img820/8637/1010549t.jpg
http://img543.imageshack.us/img543/6059/1010563.jpg
http://img823.imageshack.us/img823/801/1010565.jpg
http://img856.imageshack.us/img856/4466/1010564.jpg
If I open either of the two access panels for the drain tile system; it is perfectly dry on either end. The middle where it crosses the doorway and there is a huge drain now; is a constant flow into the system/sump.
Any help is greatly appreciated!!!
gregzoll 06-15-2011 10:41 PM
What is with the drain line in the last picture pointing towards the a/c unit? Take a picture standing farther away, so we can get a better idea of the lay of the property. I can tell you right now, the problem is a drainage issue. Not enough downspouts to move rainwater away from the foundation. If your current downspouts enter the ground, I would stop that and get them to drain away from the structure about six or eight feet. You can use plastic drain tile, or get downspout extenders that drain water away aprox five or so feet. Only way to fix the foundation, is to dig down, and use the appropriate materials to seal the foundation, and place a good french drain tile system in place. Since you are stating you are out of money, that is going to be a big issue, due to it will cost at the cheapest way aprox $50, more expensive to fix, can be anywhere $5,000 or more.
jcrack_corn 06-15-2011 11:16 PM
where the hell is that much water comming from?
1. what have recent weather conditions been, is there that much water in the ground?
2. what is the local water table.
3. busted water pipe?
i dont understand why its so wet....if it is from the environment (rain, etc) then you will never keep it out unless you waterproof from the outside ($$$).
since you say it does this 24/7, i am concerned it is more than wet ground...like a broken pipe or water table issue --- if the water table has risen then your current drain system may be inadequate.
coderguy 06-15-2011 11:21 PM
Thanks for the reply!
I actually pulled the end of that drain line up last weekend; it used to be barely visible. I'm planning to dig it out and see where it ends this weekend.
The front downspouts have been corrected and are away from house. One used to end on top of the porch! :-( The rear downspouts on both sides still enter Milwaukee's old "combined" system. You can see one on the left side of the second to last picture. The city inspector was here after the drain tile was installed and said they are functioning fine. The problem with disconnecting them is where to run things.
I will take pictures from further away and post. I will also measure the slow of the backyard.
coderguy 06-15-2011 11:26 PM
Weather in Milwaukee has been horrible :-(
It has been a bit rainy; but we had a really warm dry period and I checked it daily and even left the bilco doors open for lots of air - it didn't stop.
I'm not sure about the water table; wouldn't the interior drain tile system be wet at the access points?
gregzoll 06-16-2011 06:50 AM
The Sump should be running 24/7. Have you taken the lid off to see how much water is coming in. Also, how much is the sump cycling, and can you hear water pouring into the well.
stadry 06-16-2011 07:20 AM
( i hate this part ! )
IF the major source of the infiltrating water is around the steps, dig - dig on the outside ! bsmt systems has taken the 'french drain' to pretty-boy land but, in reality, its still a pipe under the floor altho has less carrying capacity,,, you'll need an exterior sump & pump surrounded by clean 1 1/2"- stone & soil filter cloth,,, you'll also need some shoring to prevent soil collapse while someone knowledgeable finds the directional flow of the wtr,,, you'll then need a pipe riser ( we use 24" corrugated hdpe ) so you can have access to svce the pump, etc.
most wtrproofing salesmen just want to manage interior leaking as its much easier to guarantee - most h/o buyers like it better 'cause its cheaper than exterior excavation,,, none of this is at odds w/any previous post
good luck !
coderguy 06-16-2011 07:56 AM
The water flow isn't fast enough to make it run constantly; which was the reason I tried to drill two weep holes. I thought if the water could get out it would drain away.. The old sump was going off every half hour or so? It is hard to say with the new one; as it doesn't shake the house and is pretty quiet.
I will take the lid off tonight and watch it.
coderguy 06-16-2011 07:58 AM
good luck !
Since I'm going to dig up that black pipe; I will dig a pretty big hole and see if I hit water? Otherwise to dig around the steps I have to remove a lot of cement. I'm willing to.
stadry 06-16-2011 08:04 AM
IF the water isn't running enough to make the pump turn on to discharge the collected water, that would be an indication it could be still draining into the sump BUT then hitting the soil UNDER the sump & soaking the soil underneath OR can't reach the sump due to blockage in the drainage system tho the 2nd's less likely,,, it could ALSO be an indication bsmt system's interior work was unnecessary & was based on guarantee rather than problem solving.
based on the pictures you post, there's tons of avenues for wtr to infiltrate & none have been addressed so far !
stadry 06-16-2011 08:32 AM
know the ' why ' of placing the slot drain inside the door ( 'cause its easier ! ) but the wtr in the stairwell was never addressed from what i can see.
coderguy 06-16-2011 08:33 AM
I was told by four different companies it couldn't be fixed. Basement systems was the only one who agreed to do anything; which to their credit they were very clear it was only a solution to water gathering on the basement floor. Although we all agreed the water should all drain away from the foundation after the tile was installed...
One guy honestly stood there; turned and said "so ok, what are we fixing?". Sigh.
gregzoll 06-16-2011 09:14 AM
It can be fixed, but that means attacking it from the outside to seal the foundation correctly.
jomama45 06-16-2011 10:44 AM
George,
Can you live with the wet steps on the outside of the door? If so, it would be fairly easy to remove the lowest landing at the steps, repour about 1" lower than the basement floor, and run a small drain in the middle of it to either the adjacent trench drain, or better yet, directly to the sump crock. It may not be the ideal way to control the water, but it should certainly be something you can handle with minimal damage to the wallet.
I would think that the main problem is a number of factors from what I can see:
- Those stairwells are rarely draintiled on the exterior. Mine at home certainly has no draintile, nor do most I've run across.
- Most of those stairwells walls, especially the one farthest from the basement, don't go down to the bottom of house footing. They typically step-up away from the house, making them very hard to effectively damproof & draintile.
- It's been a wet spring & summer so far. There's no doubt that the water table is high.
- You're in an older subdivision apparently, with small lots, different elevations between neighboring properties, and very little room to effectively grade the yard away for optimal watershed w/o effecting the neighboring property(s) in a negative manner.
There are many other options, but most of them are too obtrusive to recommend without trouble shooting the issues in person. If you're interested, my offer still stands. I'd be willing to take a look at it in person & see if I can give you some suggestions, free of charge of course. You would just need a little patience........ :laughing:
Best of luck.
coderguy 06-16-2011 09:30 PM
Pictures from further away
Here are some pictures from further away...
http://img191.imageshack.us/img191/8029/1010579z.jpg
http://img827.imageshack.us/img827/5561/1010580.jpg
http://img138.imageshack.us/img138/8947/1010591d.jpg
