Old 05-20-2007, 06:43 PM   #1
how to you make these?
These are relatively common on the exterior corners of properties in my area. I was just wondering how these darker blue squares are made. That house is stucco finish, and it appears (from the street anyways) that it's a smooth concrete finish on the darker blue (not the rougher finished stucco that covers most of the exterior). How do you do these? Are they structural blocks from the construction? Are they just built up stucco? Are they cast/framed in place concrete that was covered with stucco after? Were they just wood or polystyrene veneer that was affixed to the house, then covered over with stucco?
I'm about to stucco my house, and if those types of details are easy (like just carving/affixing something like eps or wood to the house) I'd love to be doing tons of accents with them.
Any input would be greatly appreciated, stucco project is on schedule to begin tomorrow!
joeyboy is offline   Reply With Quote
Old 05-20-2007, 08:35 PM   #2
In south florida alot of people put bands around the house and windows. Thats done by nailing casing bead to the exterior in the shape desired and filling the area with a 2 coat stucco process. Not sure on the blocks you want but that may be the same way.
sflamedic is offline   Reply With Quote
Old 05-21-2007, 03:22 PM   #3
They are just more styrofoam shapes over the flat styrofoam. The shapes vary.
Ron
Old 05-21-2007, 05:51 PM   #4
And for those who wish to know it's called quoining http://www.tfd.com/quoining
Zero Punch is offline   Reply With Quote
Old 05-21-2007, 05:55 PM   #5
Aha! I googled and found them pre-made for sale, damn they're expensive! I also read about just making them yourself from eps (expanded polystyrene, same/similar to styrofoam), seems like it would be real easy to make, though this is a little much for right now, I think I'll just do flat stucco around my corners.
More On This Topic
Over time, the exterior of houses will need general maintenance, including painting. The exterior of the house includes siding, trim, deck work, fences and brick foundations. Because these areas are all exposed to the weather, you will need to select... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. What I would do with this exterior is stucco. I have stucco before which is just a mixture of water and cement pour in cement and sand and you just put it on there. I understand... Read More »
Ok, we’re going to get started here. Normally the pins are going to stay in- I’m having a little bit of a problem right now, these are not very long and I don’t have it wired from the other side to help pull the wire tight. But normally... Read More »
We’ve somewhat let this sit up for a little bit. Normally, you’re going to give it a couple days to dry thoroughly. Again, you’re going to leave the grooves in there so your last coat will stick real solidly to the rest of the concrete... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
How to make room for humidifier zunk HVAC 3 02-24-2009 06:00 AM
I'm replacing screens, any tips to help make them tighter? joeyboy Remodeling 2 07-28-2007 10:18 PM
how to make an old chair look chic lovesdiy Interior Decorating 0 07-16-2007 04:07 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
