How Would You Patch This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 07:12 PM   #1
How would you patch this?
The concrete block can be removed. I'll most likely take out the step to get to it and replace the block. But with what type of mortar would you use? If at all possible I'd like NOT to have to mix anything. There are some 1/8th of an inch cracks in the basement mortar that also need repair. Would I use the same stuff?
smawgunner is offline   Reply With Quote
Old 03-24-2011, 10:38 PM   #2
Rewards Points: 5,336
Hard to get around the, "I'd like NOT to have to mix anything.", issue. It sort of limits the choices, don't you think?
Hemorrhoid cream or toothpaste comes to mind. That should fit in the 1/8" crack, so to speak.
If the restrictions ease up, let me know. We can go old school with the advice.
Ron
Old 03-24-2011, 11:17 PM   #3
Ron
So what you are saying is that you have no experience with anything that fits the bill that you don't have to mix right?... other than your sarcastic remark about toothpaste and hemmoroid cream. "limits my choices, don't you think"? I don't know...that's why am asking. Thanks for all of the great advice.
Old 03-24-2011, 11:36 PM   #4
What I'm saying is that what's required for the repair does not fall into your parameters of a solution. It makes no sense to show us a problem and start with, "I can't do this" or "I won't do that".
If you want to fix this, it's going to take, "mixing" Specifically, mortar mixing.
You take it apart, clean up the joints and reapply the mortar.
Pretty simple, but you need to be willing to make the effort.
Ron
Old 03-25-2011, 12:38 AM   #5
Ron
Apparently you didn't take the time to read my post. Never did I say "I can't do this" or "I won't do that". Reread it. I simply said "If at all possible I'd like NOT to have to mix anything.". IF AT ALL POSSIBLE. It'd be more helpful if you didn't ride my @$$ out of the gate and gave me something to go on besides sarcasm. I don't know a damn thing about mortar or cement products, that's why I asked. Again, thanks for such helpful advice.
Old 03-25-2011, 12:59 AM   #6
Too Old
How about you use some Epoxy injection resin maybe a Grade 1 Type IV, you will have to prep then fill but this is only a guess.
havalife is offline   Reply With Quote
Old 03-25-2011, 02:14 AM   #7
Electrical Contractor
kbsparky's Avatar
They make epoxy in a caulk tube, simply use your caulk gun to dispense.
The stuf ain't cheap, but the mixing part is done right in the elongated nozzle.
Here is one link for such a product.
-KB
Old 03-25-2011, 03:23 PM   #8
I've seen some concrete repair stuff that comes in caulking tubes. Maybe you can use that? Well, at least for the cracks, I don't know about the mortar, but there might be a similar product.
http://www.quikrete.com/ProductLines/MortarRepair.asp
http://www.ashgrovepkg.com/assets/pd...PAIR-CAULK.pdf
BTW, most mortar that needs mixing is "just add water" as far as I can tell. I'm no pro though. But I won't bug you about mixing because that doesn't answer your question.
Vincer is offline   Reply With Quote
EPDM Roof Patch antelope420 Roofing/Siding 1 05-11-2010 09:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 06:25 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 07:03 AM
