Old 01-10-2013, 09:41 PM   #1
How would you frame this wall?
Hello again.
Working on my plans to finish the basement and am going to use 2" XPS direct on the foundation with 2x4 walls pressed against the foam and finally 1/2 drywall.
The stairs coming in the basement are right up against the foundation. How would ever finish off this wall?
Here are some pictures....
ryanmcl is offline   Reply With Quote
Old 01-10-2013, 09:46 PM   #2
Well... i can't figure out how to post a picture...
Here is a link to them.
http://imgur.com/a/6SASv
Old 01-10-2013, 10:12 PM   #3
Here are the pictures:
Old 01-10-2013, 10:13 PM   #4
Confusing, you ask how to do it then post pictures of it all done.
Old 01-10-2013, 10:19 PM   #5
The left side of the stairs is against the foundation. The drywall you see at the top of the stairs was done by the builder and is above grade. The drywall on the right side is a wall separating the stairs from the basement. The basement is unfinished.
Old 01-10-2013, 10:41 PM   #6
not much to choose from maybe glue some 1/2 inch foam board seal tape seams then hang 1/2 drywall or better yet densglass where poured walls are at using tapcons
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 01-10-2013, 10:52 PM   #7
wont i have o move the stairs off the wall at least a 1/2 in to get a full moisture barrier? I though having that wood direct on the foundation would be a bad idea.
Interesting the builder would do this. The house is 1.5 yrs old.
The Following User Says Thank You to ryanmcl For This Useful Post:
woodworkbykirk (01-11-2013)
Old 01-10-2013, 11:11 PM   #8
Some situations call for compromise. This is where you tell yourself, , moisture barrier is more important than the insulation.
About the same as previous poster advised, although you can also put 1x furring strip, pressure treated, 24" o.c., foam panel in between, then cover with sheetrock. I used denseshield myself, but it needs to be skim coated before painting due to fibermesh skin.
carpdad is offline   Reply With Quote
Old 01-10-2013, 11:27 PM   #9
How wide is is from drywall wall to concrete wall?
As much styrofaom as you can glued to the wall. Then 1/2" drywall glued to foam and concrete screws.
mae-ling is offline   Reply With Quote
Old 01-10-2013, 11:36 PM   #10
Moderator
Is the concrete wall against the garage fill or a crawlspace? Or is it partially above grade? Or an exterior wall? Where are you located?
Gary
Clothes taking longer to dry?
Old 01-10-2013, 11:47 PM   #11
It is against garage fill. I am in northern Illinois. The foundation wall is 9 ft under grade.
Old 01-11-2013, 09:22 AM   #12
I had a pretty similar situation (maybe even tighter) and the inspector let me fasten the drywall directly to the block wall Which I did using cement nails. I did this being moisture wasn't a problem and that wall would be slightly warm than an outside wall.
As previously said, sometimes you have to compromise. Yes, if you could snap your fingers and make it 100% correct you would.
B
Beepster is offline   Reply With Quote
Old 01-11-2013, 11:34 AM   #13
"You can do anything"-Mom
brockmiera's Avatar
I have this same situation in my home and I 'm not sure what to do either. Hopefully someone here has done it and can shed some light on it for us.
On a side note: I don't think you should be spending money putting pink xps on an interior wall.
brockmiera is online now   Reply With Quote
Old 01-11-2013, 11:39 AM   #14
Here if your stairs are wider then 36" drywall to drywall you can make them narrower and then put in as much xps (foam) as you can then use concrete screws on the drywall.
Old 01-11-2013, 12:09 PM   #15
Currently from drywall to drywall at the top the are 39". Would i remove the entire stair case to modify them?
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-13-2012 12:36 AM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
