How Would You Frame This? [pics] - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2007, 04:51 PM   #1
How would you frame this? [pics]
Okay, Im about to start finishing off my basement so I have a few things to do before I can get started. There is a portion of my basement that has ducts and a support beam that are lower than the rest of the floor joists.
I've attached some pictures so you can see what I am talking about:
So I have two issues I guess. The first being that if I frame it off starting at the lowest point, that red beam, then it will cut off about half of the window there. Or else, I could across to from the red beam to the start of the window, then up and across just under the ducts. If I do that, then it leaves me very little room to place pot (inset) lights. I was hoping to be able to place them in the middle between the beam and the ducts, but I don't think I'll be able to with the window. I think they'll have to go almost directly behind that beam. Do you think that will be a problem?
What would you do here? Any advice? I thought about possibly just removing the window, but I'm not sure about code on that.
abstracted is offline   Reply With Quote
Old 03-28-2007, 04:53 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Drywall or drop ceiling?
Brik is offline   Reply With Quote
Old 03-28-2007, 05:01 PM   #3
Sorry I should have mentioned, drywall.
Old 03-28-2007, 07:30 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
Problem I see in the pics is that you have so much wiring and other lines running along the sides of the duct work where you would normally be framing to box-in your duct work.
You might want to consider a dropped ceiling (acoustic ceiling)...
- Build Well -
Old 03-28-2007, 07:32 PM   #5
2nd thought too...
In one pic you have a plumbing drain line with a 'clean out' that you want accessible.
In other words, you wouldn't want to box something like that in with sheetrock...
- Build Well -
Old 03-28-2007, 08:41 PM   #6
yummy mummy's Avatar
Rewards Points: 1,016
Where is beer geek when you need him!
(To inspect the spacing of receptacles).
Now where are you beer geek?
yummy mummy is offline   Reply With Quote
Old 03-28-2007, 08:49 PM   #7
You're a trouble maker.....
- Build Well -
Old 03-28-2007, 09:28 PM   #8
Remodeler
MinConst's Avatar
From the way I see it from the pics. You could attach the drywall to the side of the the main beam and then carry over a drop ceiling that should cover the duct work. Drop the ceiling just under the drain so you can access it from a ceiling panel. Box in the window with a 1x6 or 1x8 put a roof on it and you won't loose the window. You also gain allot of light this way. Make the window box 12" wider than the window and around 8" out from the wall.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-28-2007, 09:54 PM   #9
... Agreed.... All good suggestions... Minconst...
- Build Well -
Old 03-28-2007, 10:04 PM   #10
I know, I work hard at it.................
Old 03-28-2007, 10:11 PM   #11
Rewards Points: 150
You're not very bright, are you?
You're giving me grief because I pointed out the code violations in your shoddy work. That's great. You really have a leg to stand on.
Perhaps you shouldn't post while drunk.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-28-2007, 10:13 PM   #12
Hey guys, thanks for the response.
Most of you are saying drop ceiling, but I'm pretty set on drywall right now. It's a lot cheaper, and it's not hard to patch it if I do have to take some apart for repairs down the road.
As far as the cleanout drain, you can see in one of the pictures that the pipe heads to the ground along the wall. At the bottom is where the actual clean out drain is, so that should be fine.
Here is a picture of what I think would be the best idea to do. Kinda of like a cross-section, if that makes sense.
Old 03-28-2007, 10:16 PM   #13
Drunk" I'm not the one called "beer geek"!
You sound too tense beer geek, relax, take a deep breath.
Old 03-28-2007, 10:30 PM   #14
Rewards Points: 150
Tense? Hardly. I'm not the one taking shots out of nowhere. This is twice that you've done it. Perhaps you should use some of your psychology training on yourself. Is it really gnawing at you that I didn't validate your work? Sorry that I tried to help you by pointing out your code violation. One would think that most people here would appreciate that sort of thing.
Old 03-28-2007, 10:40 PM   #15
Remodeler
MinConst's Avatar
I don't know about cheaper if you take into consideration the time involved to fram it and rock it.
Unless your sinks plug up. Looks like a bathroom above that area.
Kinda hard to tell from the pic. Your there and have the best eyes for it.
Web
One Man Shops
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
how do i put a frame on uneven drywall jerry1967 Building & Construction 4 12-02-2006 03:38 PM
(urgent!) Covering/repairing damage on wooden door frame? Photinus General DIY Discussions 2 07-19-2006 08:25 PM
Hybrid Timber Frame 4powells Building & Construction 2 05-03-2005 10:14 AM
mirror frame jdwdwd Carpentry 3 03-31-2005 10:34 PM
