How Would You Frame Around This Drain Pipe. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 03:41 PM   #1
How would you frame around this drain pipe.
The pipe in question is the 4" drain pipe running horizontal at the top of the wall. Approx 30'.
I know I could just move the wall in front if the pipe but I don't wan to give up the space.
http://i.imgur.com/0R2kB.jpg
The biggest question is how to i secure the wall if the top plate does not his the floor joists.
I plan on having 2" XPS direct on the wall behind the frame.
ryanmcl is offline   Reply With Quote
Old 01-20-2013, 06:25 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,108
just move the wall out from the foundation. no notching required in the plates or studs
woodworkbykirk is online now   Reply With Quote
Old 01-20-2013, 06:54 PM   #3
Just build the wall in front of the utilities! You will lose about 8" but this will be unnoticeable, in most cases.
If the wall is built away from the foundation, care must be taken to observe local building codes regarding fire blocking.
Old 01-20-2013, 07:32 PM   #4
Ok. Should i put some blocks in to hold the XPS or just hope my glue holds up over time?
Old 01-20-2013, 09:30 PM   #5
A suitable adhesive will outlast the XPS!
Have you considered having the insulation sprayed on?
Old 01-20-2013, 09:35 PM   #6
I have thought about it. However, I see lots of comments about it being very expensive.
Guess i should get some quotes.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 01:48 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
