How Would You Fix This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 04:43 PM   #1
How would you fix this?
I replaced a piece of sheetrock in my garage. I taped it last night. Now there seems to be a couple small air bubbles maybe the size of a corn kernel under the tape joints in a couple places. Is there a way to flatten these back out? Should I just mud the hell out of it to raise the surrounding area level with the slightly raised bubbles, or should I replace that piece of tape?
Thanks!!!
mopowers is offline   Reply With Quote
Old 09-15-2009, 04:49 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
can you slit with a razor and just skim over?
Mr Chips is offline   Reply With Quote
Old 09-15-2009, 09:03 PM   #3
Remodeler
MinConst's Avatar
Thats the ticket. Cut out the bubbles and fill with the next coat of mud.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-15-2009, 09:04 PM   #4
Old School
Willie T's Avatar
Like chip said... two curved razor knife cuts intersecting at their ends in the shape of an almond around each bubble so that all the high stuff is removed. Then just smoothly skim coat it.
Willie T
