How Would You Do This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2013, 07:39 AM   #1
PoleCat's Avatar
Rewards Points: 1,652
How would you do this?
The back of our house is getting a mirror image of the front roof. It will be a hip roof with a dutch gable. I have to put in some double 2X10 or 12 beams from the post to the walls. How would you go about attaching these to the walls so that they will carry the load of the new roof? The walls are 2X4 @16OC with solid 1X8 pine siding.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-04-2013, 12:53 PM   #2
Rewards Points: 502
Don't understand what you mean by a 'hipped roof with Dutch gable'?
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
MTN REMODEL LLC (06-04-2013)
Old 06-04-2013, 01:07 PM   #3
Old School
Willie T's Avatar
Maybe, "Caribbean hip"?
Willie T
Old 06-04-2013, 01:15 PM   #4
Rewards Points: 502
The problem with roof terminology is that it frequently depends on where you are.
Old 06-04-2013, 02:17 PM   #5
PoleCat's Avatar
Here is what I am calling a dutch gable.
What else would this sort of structure be called?
So how would a seasoned carpenter marry the beams to the walls? These beams will carry new rafters.
Old 06-04-2013, 03:03 PM   #6
Rewards Points: 502
Polecat, I stand corrected!
Just googled dutch gable and it shows roofs as you drew it. (I would have called it a 'hipped roof with gablet'); learn something everyday.
Old 06-04-2013, 04:03 PM   #7
PoleCat's Avatar
I had to look it up myself. Lived here 20 years and just called it "roof".
The Following User Says Thank You to PoleCat For This Useful Post:
