How Would You Clean This Brick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 05:42 PM   #1
How would you clean this brick?
Hi,
I'm rehabbing this home, built in 1930, and need to do something about this brick. I'm not sure what is on it or what/how to clean it. There are some cracks that I'm going to have repaired by a mason, but I thought I should clean the brick first as the cleaner may be hard on the new mortar? I appreciate any feedback.
chris
How would you clean this brick?-brick-pic-1.jpg   How would you clean this brick?-brick-pic-2.jpg   How would you clean this brick?-brick-pic-3.jpg
cmuzz00 is offline   Reply With Quote
Old 06-30-2011, 05:54 PM   #2
Rewards Points: 5,336
Powerwash it.
Ron
B. Franklin 1759
Old 06-30-2011, 08:23 PM   #3
DIY staff
Rewards Points: 7,174
You should go to a brick yard and ask what cleaners they have---a mild acid may be required.
Parts of that have been recently tuck pointed---the white is likely lime from the new mortar.
I hesitate to mention products --what I use is rather dangerous in untrained hands.---Mike---
Old 07-01-2011, 09:30 AM   #4
AGWhitehouse's Avatar
I agree with Mike...
AGWhitehouse is offline   Reply With Quote
Old 07-01-2011, 04:02 PM   #5
Rewards Points: 1,232
At some point there was stucco over the brick, and as noted some of it has been tuckpointed. Why do you want to clean it? If you want it all to be an even color and the same as the lower portion, it isn't going to happen.
Powerwashing brick with anything other than a fan tip is not advised, especially with acidic cleaners.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 07:21 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
Brick face house clean up - improvement jovo14 Building & Construction 1 08-09-2007 03:40 PM
