Old 10-27-2008, 12:47 AM   #1
yummy mummy's Avatar
How would I trim around a light switch?
I placed a light switch really close to the edge of an outside corner and now I am wondering how to trim around it?
I assume I just cut into the trim?
yummy mummy is offline   Reply With Quote
Old 10-27-2008, 08:54 AM   #2
Moderator
Termite's Avatar
Can you describe in a little more detail or post a picture? Can't picture how or why an outside corner would have any sort of trim on it.
Old 10-27-2008, 08:56 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Y.M.
I'm a little lost by your description of outside corner. I am going to assume that you mean the outside of a section of casing or molding?
- Build Well -
Old 10-27-2008, 09:29 AM   #4
Hi Y.M.,
Generally, light switches should sit clear of moldings. Cutting into trim work/casing/molding for a light switch is never a very pretty sight.
If, you have no other choice, or it's no big deal to you, then you can go ahead and do it.
Here's a picture that may, or may not help you (this was in my own home - the switch was already in that location, and I added nicer door casings and moldings) (Also: Yes the light switch, itself, still needs to be changed over to a darker color to match the switch plate covers):
- Build Well -
Old 10-27-2008, 09:40 AM   #5
Moderator
Termite's Avatar
Sometimes you can trim the edge of the light switch, provided it isn't more than 1/4" or so. I've done this on the bandsaw a time or two. What you can't do is have wood trim exposed to the inside of an electric box.
Old 10-27-2008, 09:59 AM   #6
In that situation, it looks better to trim the switch, i.e. put a backing plate under it that matches the trim and brings it out to the same plane as the trim.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 10-27-2008, 10:03 AM   #7
the Musigician
DangerMouse's Avatar
if you have access to the wall, can you perhaps simply add a 2x4 block to the stud and move the box over that inch or so and redo the wall?
i agree with the guys, anything that cuts into the moulding looks ...well, you know.
DM
Old 10-27-2008, 05:52 PM   #8
Jay123's Avatar
Not that these are "outside" pics, but may give you some idea how to tweak things...these are a few years old, so please forgive the quality.
J
How would I trim around a light switch?-rca_0176.jpg   How would I trim around a light switch?-dscn0700.jpg
Jay123 is offline   Reply With Quote
Old 10-27-2008, 05:53 PM   #9
That is what I was talking about.
Old 10-27-2008, 07:28 PM   #10
BUILDER / REMODELING CONT
buletbob's Avatar
Nice work Jay123.
Old 10-27-2008, 07:34 PM   #11
Jay123's Avatar
Thanks guys. It's been awhile...I would stand around scratching my head quite a bit if I had to do it tomorrow . But you know how it goes, you usually figure out something that will work (hopefully).
J
Old 10-27-2008, 10:01 PM   #12
Agreed.
- Build Well -
Old 10-27-2008, 10:03 PM   #13
J
When you can incorporate the wood work, it's always a good method.
- Build Well -
Old 10-27-2008, 10:06 PM   #14
Electrician
That is pretty ugly, what was so wrong about putting the switches inside the panel, People pay some pretty good money for some pretty crappy work.
chris75 is offline   Reply With Quote
Old 10-27-2008, 11:45 PM   #15
CHRIS, not fare.
You know carpenters will do just about anything to save the $ 125.00 trip charge to move a switch.
Big Bob is offline   Reply With Quote
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
