HOW: Wood Railing/posts Attached To Brick Steps? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2009, 01:56 PM   #1
HOW: Wood railing/posts attached to brick steps?
Please / Thanks -
1910 Craftsman-style house w/brick-step front porch; want to attach wood railing; wondering if concrete anchors drilled into the brick are sufficient for the posts, or whether I should drill deeper on the assumption/hope there is solid concrete under the bricks?
Recommendations/experience(s)/thoughts?
Many thanks.
TheHiker is offline   Reply With Quote
Old 03-27-2009, 07:14 AM   #2
Rewards Points: 5,336
I would use lag bolts and lead anchors. Get bolts long enough to penetrate the masonary by 3"
An alternative would be to epoxy bolts into the stoop and use nuts and washers.
Ron
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Brick steps failing sk8z Building & Construction 10 03-28-2009 04:16 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 09:06 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
