How Are Wall Studs Attached To The Sole Plate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 09:41 PM   #1
Rewards Points: 682
How are wall studs attached to the sole plate?
How are wall studs attached to the sole plate at the bottom of the wall? It looks awkward, the only way I can see is either with plates or by driving in nails at a 45 degree angle . From what I can see in constructions sites there arent too many plates down there .
It seems like a critical place in the frame , a couple of nails at 45 degrees doesnt seem right.
darsunt is offline   Reply With Quote
Old 04-20-2009, 10:03 PM   #2
Civil Engineer
Rewards Points: 4,568
If you prebuild the wall (very common), it is common practice to drive two 16p nails into the stud through the sole plate from the bottom. If the sole plate is already in place, you can toenail the stud in, with 2 nails per side (4 total). Or you can use Simpson connecting brackets.
Old 04-20-2009, 10:12 PM   #3
The weakest attachment is driving from the bottom. Toenailing is actually very strong. You can stand a toenailed wall up even in a moderate wind and it will stand by itself. You cannot do this with a wall that has been nailed to the plate first and then stood up. You'd be surprised how hard those toenails come out. On another note, in some areas special tie downs and strapping is needed to withstand hurricane force winds.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 04-20-2009, 10:23 PM   #4
Old School
Willie T's Avatar
Here are a couple of versions of the same article.
http://www.wikihow.com/Toenail-Wood
http://www.rd.com/18178/article18178.html
Willie T
Old 04-20-2009, 10:25 PM   #5
Structural Engineer
Technically toenailing should be done at 30 degrees from the vertical, per the NDS.
Simpson connectors are always preferred, because it tends to keeps the nails in shear only.
wildcat is offline   Reply With Quote
Old 04-21-2009, 11:57 AM   #6
Rewards Points: 682
Thanks guys for showing me how its done!
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Nailing studs to sole plates bluefitness Building & Construction 6 12-15-2008 11:54 PM
Rotted sole plate in bathroom firemanter Building & Construction 3 11-11-2008 11:06 PM
Studs to Sill Plate Tim Building & Construction 4 09-24-2006 03:23 PM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-23-2006 12:01 AM
