How To Vinyl Side This Odd Area? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 01:16 PM   #1
the Musigician
DangerMouse's Avatar
how to vinyl side this odd area?
how would i go about doing this area above the 6'x6' windows with this damnable 2x12 perimeter beam overhang to allow proper water flow in the rare event of sideways rain? i have undersill and J-channel to work with,
how would you pro siders do it? is there something more i need to get?
DM
Old 04-19-2009, 02:20 PM   #2
waterman1971's Avatar
Rewards Points: 154
Run the wall siding up on the bottom section. Make a transition piece out of coil to finish it out.
waterman1971 is offline   Reply With Quote
Old 04-20-2009, 08:59 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Are you equipped to bend aluminum?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-20-2009, 10:13 AM   #4
the Musigician
nope, is there a vinyl piece i can adapt?
DM
Old 04-20-2009, 10:36 AM   #5
Rewards Points: 5,336
With that extent of siding, you should rent a break if you can't borrow one. Many of the transitions you'll come accross won't have ready made solutions.
Ron
Old 04-20-2009, 12:07 PM   #6
Rewards Points: 1,910
I think I saw a brake rental at Home Depot for around 45$ per day.
Old 04-20-2009, 04:51 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'd highly recommend renting a brake---that is, if you know how to use it. If not find, someone who does to help you on your project because that isn't the only place you'll need bent aluminum, otherwise you'll have water issues.
www.HomeSealed.com
Old 04-20-2009, 05:07 PM   #8
the Musigician
where else would i need it?
DM
Old 04-20-2009, 05:11 PM   #9
the Musigician
couldn't i use E or H on this page? i want all vinyl, no aluminum.
http://products.construction.com/swt...974/E66361.jpg
DM
Old 04-20-2009, 05:15 PM   #10
the Musigician
what do you mean? this is the only odd place i need to deal with that i can see. all the rest is windows with built-in J-channels and the doors...?
straight shot all around.
DM
Old 04-20-2009, 08:48 PM   #11
knewbie
curapa's Avatar
DM
What about the coil stock on the facia board? Or are you using wood facia?
I would bend coil stock for the situation in your picture.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 04-21-2009, 02:14 AM   #12
Tom Struble's Avatar
Rewards Points: 2,002
do you hammer lefty DM? i see your tyvek is upside down like mine is
Tom Struble is offline   Reply With Quote
Old 04-21-2009, 04:49 AM   #13
Pro Trim
Check out a product called pro-trim vinyl coil. It can be hand bendable but still a break is eaiser. It sounds like that is what you desire since you do not want aluminum. Have used it once before a couple of years ago for a coastal enviroment. Smaller pieces gave a better appearance over wider pieces. You can get it in a smooth finish or a wood grain.
marlinpuppy is offline   Reply With Quote
Old 04-21-2009, 05:24 AM   #14
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That area needs to have a section of 1x stock attached to it, prior to installing aluminum over it.
Alternate method: Install a PVC type 1x stock over, like a horizontal corner. Install a drip cap over the top. Install J channel along the edges.
- Build Well -
Old 04-21-2009, 07:27 AM   #15
the Musigician
tom: actually, i hammer with my feet, like all good little monkeys do!
curapa: i'm using pre-shaped aluminum for the fascia boards. couldn't find vinyl.
atlantic: please elucidate. i do not understand the terminology. do you have pics of what i need?
anyone: can't i take strips E or H, (link to pic above) and trim off what i don't need to wrap around the edge with a fine-tooth blade on my table saw?
i'm also considering a 2 or 3 ft. overhanging, shingled awning to keep water away from the picture windows. maybe even all the way across the whole front of that area! that should end my problem by completely covering that whole section...any suggestions? reasons why not? code as to how it needs to be built/attached?
DM
glueless Vinyl product NoviceDIY Flooring 7 08-20-2010 05:52 AM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
Vinyl Siding just blew off the side..... Scott_K Building & Construction 5 01-17-2006 10:17 AM
