-   -   How to update an old home heating vent (http://www.diychatroom.com/f19/how-update-old-home-heating-vent-43028/)
heater 04-22-2009 12:29 PM
I have an old farm house (about 130 years old) and have been busy updating our living room area. I opened up the living room by knocking down a wall between the living room and the hallway. My question is: In the hallway I currently have an old home heating vent pipe that is square and approximately 8 x 16. I would like to update this to something that can still provide the required air flow plus allow me to downsize so that I can place the pipe into a side wall instead of walling the area off where it is. I am looking to open up the two spaces and this pipe currently sits about 2 feet away from the wall and if left as is the two spaces would still be divided by a jog out that would defeat my purpose of keeping the space wide open.
Any suggestions?
Ron6519 04-22-2009 03:26 PM
Originally Posted by gtglobe (Post 264019)
I think these points may help you...
To keep your vents operating efficiently and to deal with problems like those outlined above, here are a few tips for cleaning these important areas of air exchange in your home:
1. Keep the vent areas free of clutter. Don’t' stack boxes, magazines, or other items in front of the vents, and don't push furniture in their way, either. The vents promote the ventilation of warm air throughout each room in the house. When not in use, close one or more vents, but never cover or obstruct them when in use. Encourage family members to keep personal items away the vents in all living areas.
2. Dust, mop
, or vacuum around the vents weekly. If you look closely, you may see a thin trail of dust or furnace debris around the exterior of the vent. Wipe the surrounding wall space. On light surfaces you may be able to see dust particles. Keep the external areas wiped clean to prevent an accumulation of grit or grime.
3. Unscrew the vents and carefully remove foreign objects. These may include the above-mentioned coins, pills, toys, or other small objects that have been accidentally or deliberately tossed into the vent grate. If something cannot be reached by hand, look for an appropriate-size handle-type object with which to retrieve the lost item. Be careful not to get burned or shocked, depending on the structure behind the grate.
4. Gently vacuum inside the vent. Look for the largest clumps of dust and get these first. Then sweep the air generally to get rid of particles, dust bunnies, pet hair, and other debris that may be collecting inside the vent. Since warm air will push out these minute items into the air that family members breathe during the winter, you want to get rid of as much as you can to keep it from circulating throughout the house. Do this for all the vents you can safely reach.
5. Clean the grates. Wipe them clean with a damp cloth, watching for rusty metal areas so you don't get scratched. Replace the grates when you are done, screwing them in tightly so they will not come loose, but not so tightly that you strip the bolts. Clean up the resulting debris, if any, that may have jarred loose as you removed and cleaned the grate. You may want to wash nearby curtains or wipe off furniture if the vacuuming and cleaning caused some of the dust to swirl around.
She wants to move the heating duct, not do spring cleaning.
Ron
Ron6519 04-22-2009 03:30 PM
Any suggestions?
It can be moved, but in doing so the added jogs will slow down the air flow. I don't think you can reduce the duct size without losing necessary heat.
I would have an HVAC guy come in and get his advice.
Ron
Gary in WA 04-22-2009 05:45 PM
I second that ---- what Ron said. A pro would mathematically balance your system for the new requirements.
Be safe, GBAR
Chemist1961 04-23-2009 06:20 AM
For best results post your question in the HVAC forum, there at least 3 pros on there frequently:thumbsup:
