How To Turn A Garage Door Into A Walk In Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 09:27 PM   #1
How to turn a garage door into a walk in door
I have one of those 5 bay shops. It doesnt have a walk in door so when i want to go in i have to open a garage door. I would like to add a walk in door.
Now i have 2 choices that i can see:
1. Convert one of the bays to a wall with a walk in door
2. Cut the concrete foundation/siding to put in a walk in door in the side of the building.
I am wondering which would be easier for me to do on my own? The inside is unfinished so there is no problem there. The concrete foundation is about 3 ft high i think.
Thanks for any input or ideas
wraptorman is offline   Reply With Quote
Old 11-15-2011, 09:40 PM   #2
Rewards Points: 5,336
Do you need the 5 th bay? Will you need it in the future?
I've seen man doors integrated into garage doors in many places. Maybe you could integrate one into yours.
Don't know if a kit is available to retrofit a door into one that wasn't engineered to have one initially.
Might check the door manufacturer.
Ron
B. Franklin 1759
Old 11-15-2011, 09:54 PM   #3
firehawkmph's Avatar
Rewards Points: 1,884
I don't think cutting out the block for a man door would be that big of a deal either. Just add a little extra width for some wood framing.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-15-2011, 10:28 PM   #4
Registered User
Rewards Points: 5,520
Those both sound easier than adding concrete or block next to the man door, getting any added wood siding/framing at least 2" above the splash line per Code. Steel may be different...
Gary
Old 11-16-2011, 12:02 AM   #5
liscenced electrician
Rewards Points: 538
how bout some pictures?
jimmy21 is offline   Reply With Quote
Old 11-16-2011, 07:34 AM   #6
joed's Avatar
Rewards Points: 12,926
Replace the door with one that has built in man door.
http://www.walkthrugaragedoors.com/
The Following User Says Thank You to joed For This Useful Post:
oh'mike (11-16-2011)
Old 11-16-2011, 09:22 PM   #7
Rewards Points: 502
there is no reason you just can't cut a door and add door hinges and hardware. you just have to have extra garage door hinges holding the sections together.
forresth is offline   Reply With Quote
The Following User Says Thank You to forresth For This Useful Post:
Gymschu (11-17-2011)
Old 11-17-2011, 07:44 AM   #8
Gymschu's Avatar
Rewards Points: 846
I have actually done this with a garage door that would not open properly. It was a wood door by the way. I simply cut it so I had a 36" section with which to create a door. I incorporated the windows into the door..........after cutting the door, I reframed inside the garage so I had enough framing to support a HEAVY 36" door. I used 4 large (gate type) hinges and simply attached them to my newly created framing and to the door. It has been that way for 8 years. I did add a turnbuckle assembly to the door to keep it from sagging. It can be done!
Gymschu is online now   Reply With Quote
2 Door Garage to a 1 Door Garage? jpearson311 Carpentry 43 02-20-2010 12:56 PM
Garage Door Opener Help chard General DIY Discussions 5 02-03-2010 05:06 PM
Garage Door Questions: closing sides and safety reversal jage Building & Construction 10 11-10-2009 07:57 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Garage Door Insulation PaliBob Building & Construction 4 03-27-2009 03:05 PM
