#1 |
the Musigician
how to trim out this light with vinyl?
any suggestions on how to make this look right/good?
tnkx DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#2 |
Moderator
I see them mounted on light blocks, 5/4" cedar, then J next to, flash over,rubber gasket under fixture. That....... was alot of commas!
Be safe, G |
#3 |
how to trim out this light with vinyl? |
#4 |
#5 |
the Musigician
hmmm... those would really make it stick out from the wall....
can i...... take some sheet rubber from an old roof, staple it to the sheathing, J-channel around the area and mount the light that way? then i'd just have black around the edges. orrrr..... i can cut some vinyl strip to fill in the same areas? the light is high up with a 2ft. overhang, so i don't worry about wet at all. tnkx! DM
#6 |
the Musigician
here's how i decided to do it.
(thanks for the ideas though, but a block would stick out too far.) i cut corner pieces from flat scraps, left the rubber gasket, (didn't even have to undo the fixture!), siliconed the edges and used it to stick the pieces as well, then did J-channel around. the lamp i got for $3.00 at Habitat for Humanity ReStore and rewired in a new socket and painted it. How's it look? DM
#7 |
Old School
Since you don't have any water to worry about, I think that turned out really well. I actually like it better than the typical block.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#8 |
Xtreme DIY'r
Much cheaper then that block too
#9 |
might be a problem if you ever want to change the fixture but well done
#10 |
without the common light box I think I wouldve extended the wall box to come out to the same width as the siding then sided up to it, installed the light over the siding and then siliconed around the perimeter. The siding looks thin enough and IMHO, the J bead looks kinda cheesy Mouse.
#11 |
i tend to agree the lite block really only extends about 1/2'' or so past the siding,but you did a nice neet job on your install
| Display Modes | |
| Installing recessed light trim | helpless handyman | Electrical | 18 | 07-30-2009 05:35 PM |
| White vinyl windows with wood trim... crazy? | rnjsbungalow | Interior Decorating | 5 | 04-16-2009 06:53 AM |
| Sidelight - Cannot find vinyl trim | lrichards | Building & Construction | 2 | 08-28-2008 05:42 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
