Old 11-06-2009, 10:05 PM   #1
Arrow How to tile around a Pre fab shower base
Ok, I can certainly use some help and guidance with this one. I am finishing the bathroom in my basment. I am putting a round glass standing shower stall, the kind that come with a pre fab base. I have seen that he ones at home depot have a 'lip' on the base that you can put screws through and make sure the base stays in its place once installed. Mine does not have that kind of a lip that I can drive a screw through. It just has a bevelled edge.
Also, the base has small legs that can be screwed in and out to adjust their height. The place that I bought the shower from told me that the base would not move after it is installed if installed correctly. The correct method of installation is that the floor tile must go but agains this base. My contractor tells me that he is not sure if the tiles could be cut clean enough to have a nice clean edge around the shower base. he thinks that the tiles would be jagged around the shower base. To avoid this situation, he wants to tile all the way through under the base of the shower and then put the shower base on top. My concern is that this way, there is nothing that will keep the shower base and hence the shower from moving. Does anyone on the forum hass any experience with this type of shower base and what do folks here say about tiling around the shower base and under the shower base.
Thanks folks
geoffthemonk is offline   Reply With Quote
Old 11-07-2009, 11:10 AM   #2
I have not worked with this particular base, but a typical installation would have globs of mortar underneath the base to keep it from sagging and bending under the weight of the person in the shower. That would help to keep the base where it belongs. The more I think about it, the more I realize that I have never seen a base without some means of attaching it. Are you sure that there is no specially made anchoring hardware that came with it? If not, maybe you can fabricate something out of flat stock steel, say 6" long by 1-1/2" wide, and 1/8" thick. Heat it up with a torch and bend it to look like a "J", and drill a few holes in it. Then mount these to the studs so that they catch the bottom lip of the base, and keep it from creeping away from the studs. Also, as a sidenote, is there any kind of channel or other means of keeping water from getting behind the unit?
CustomBuild is offline   Reply With Quote
More On This Topic
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can visit blackdogvideo.biz on the internet. Okay, we... Read More »
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
With today's busy schedules, it's difficult to find time to relax and pamper yourself. But you don't have to go to a vacation resort to feel spoiled. By installing a multi-head shower, you can turn your own shower into a mini-spa. Read on to learn how to... Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
Removing solid shower base with marble chips WoozyChain Plumbing 2 08-15-2009 09:10 AM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 07:58 AM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 04:30 PM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 09:40 PM
Building a tile shower ghostrider20 General Discussion 2 03-01-2007 10:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
