Old 11-08-2009, 01:54 AM   #1
Default how to tie down roof trusses
We have just discovered that our builders did not tye down the roof trusses with hoop iron now we need to do this but the building is built (not plastered) how do we tie the roof trusses down now? there are four rooves 15 x 8 meters in size and we live in the mountains so winters can be windy in Cape Town, advise would be appreciated.
nicolebrunda is offline   Reply With Quote
Old 11-08-2009, 05:45 AM   #2
General Contractor
Is the sheetrock hung yet? I have never seen hoop iron used to tie down trusses. We use H1 clips around here, you should call your building official and ask how they are supposed to go on. But if code requires it and your builder left it off, he should come back to take care of that.
KennMacMoragh is offline   Reply With Quote
Old 11-08-2009, 06:59 AM   #3
If your internal wall is blockwork, this method may be acceptable. However, your Regs may require something different.
stuart45 is offline   Reply With Quote
Old 11-08-2009, 07:44 AM   #4
Framing Contractor
Why is this your problem to fix? What happened to the builder? Did you have a framing inspection?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-08-2009, 10:13 AM   #5
Civil Engineer
If this is Cape Town, South Africa, procedures are likely to be radically different than anything in the States.
Old 11-08-2009, 10:16 AM   #6
Extreme DIY Homeowner
Scuba_Dave's Avatar
IP does track to South Africa
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
My name is Brandon Sarkis, on behalf of Expert Village. Today, I'm going to show you how to roast a traditional Christmas duck with red currant jelly sauce. And now would be a good time to turn our oven on to 425. So I've gone ahead and turned it on. Now... Read More »
Hi my name is Dan and I'm here with Expert Village and today I'm going to show you how to tie a truckers hitch. Which functions very much like a two to the one pulley and it is a excellent method to making the ridge lines for tarp setup very tight. Make... Read More »
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 09:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 06:08 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 10:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
