Old 07-22-2009, 10:49 PM   #1
Question How to tie in???
I have a 20' tall brick veneer exterior wall. I'm gonna add a screened porch. I want to drop below the existing roof (to 17' High) and build a new hip roof. Because there is not a rim joist at 17' to bolt into, how will I tie the band joist of the roof addition to the brick wall? I'm in NC.
timfresh is offline   Reply With Quote
Old 07-23-2009, 06:19 PM   #2
Most building departments won't allow brick veneer to be used to structurally support ledgers or joists. Some will allow lagging or bolting through the brick to studs or rim joist and other locales will require you to remove the brick in that area and attach directly to the framing. Time to talk to your friendly building department to find out what is ok in your area.
More On This Topic
Decorate your dollhouse just like you would decorate your real fantasy house. You can let your imagination run wild, without the worry of functional details or comfort of the occupants. The only guidelines to follow when decorating a dollhouse are to... Read More »
Making a masonry planter is a good way to add aesthetic value to your home. They work well in yards and can also be used to add foliage to areas that are covered in concrete, tile or other non-dirt surfaces. Read More »
Before anyone breaks you have to see who breaks by what is called the lag. The lag is when you have both players, or remember this game can be played with team mates. You could have two on two or one on one. One of your players of each team, if it is... Read More »
Hi! I'm Mark Sullivan for Expert Village and today we are going to learn how to build a barbecue pit. I am going to now push some of these outside bricks up to them to kind of secure them into place. We are going to take our paver and bring them right up... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
