How Are These Roofers Removing Shingles? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 10:08 PM   #1
Rewards Points: 682
How are these roofers removing shingles?
I saw some roofers removing shingles with a tool that looks sort of like a shovel, but with a flat head.
Are they just cutting off the nails at the top of the sheathing? It seems too hard too pull all the nails out.
darsunt is offline   Reply With Quote
Old 01-06-2011, 10:13 PM   #2
There are different models
I have one, it does get most of the nails out
Old 01-06-2011, 11:07 PM   #3
Registered User
Rewards Points: 526
Yours still looks like new, Dave. lol
Gary
Old 01-07-2011, 05:40 AM   #4
Framing Contractor
I've seen most roofers use one like this.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-07-2011, 09:18 AM   #5
cocobolo's Avatar
Rewards Points: 6,114
And before they made these nifty little tools, we used to use a garden spade, the type with the straight, flat end. They still remove shingles and most nails very well...cost less too.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 01-07-2011, 10:50 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
And talk about blisters, even with tough hands, but they sure work.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-07-2011, 10:56 AM   #7
Gary
Yeah I can't remember if I had it at the last house
5 layers of shingles on most of the roof there
I just grabbed one edge & peeled it all back
Top layers were only nailed into shingles
I think I estimated the weight at 15,000 lbs
Old 01-07-2011, 11:01 AM   #8
Rewards Points: 682
I'm glad they get the nails out. I guess they must pop out when you whack away under the shingles. I didn't notice them doing much prying.
I may have to buy one of those in the near future.
Old 01-07-2011, 06:49 PM   #9
Hi
In the UK for small repairs we would use something called a slate ripper!
As per attached image!
Regards
hereslookingatU is offline   Reply With Quote
Old 01-07-2011, 10:17 PM   #10
Registered User
Rewards Points: 526
We have those by another name, shingle rippers. Not much slate over here compared to shingle side wall and earlier shingle roofs (were the norm many moons ago....) Installation cost and quality installers along with old growth trees limited the supply and demand now.
The neatest trick roofers use around here is a tool like Joe pictured with another worker rolling the wood shingle, composition and tar paper all up in 6' sections like sod, then toss into dumpster/truck from the roof. Very limited loose material left after two guys roll the double course of material efficiently.
Gary
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Ask roofers to cut back shingles extension from 1 to ? sophie10 Roofing/Siding 14 10-27-2010 09:01 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Removing asphalt shingles stevez Roofing/Siding 5 04-27-2009 03:35 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
