How To Stand Up Tall Wall 20'x 19' - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 07:52 PM   #1
how to stand up tall wall 20'x 19'
I plan to build house, who know how to stand up 20' tall and 19' long framming wall? thanks.
yuzhenli is offline   Reply With Quote
Old 01-31-2010, 07:55 PM   #2
Fully framed & sheathed ? A crane
Old 01-31-2010, 07:59 PM   #3
who know some hand tool or small machine?
Old 01-31-2010, 08:03 PM   #4
I raised a ~24' long by 8' without sheathing using a winch
But I had a raising point 20' off the ground pulling the wall up
I also used 2x's as braces on the opposite side
With enough people & 16' long bracing you could raise it by hand
Old 01-31-2010, 08:28 PM   #5
firehawkmph's Avatar
Rewards Points: 1,800
Yuzzi,
Please don't take offense, but for someone who wants to be his own general contractor, it seems from your questions you know very little about the homebuilding process. I built custom homes for many years, and it is a process that is involved, and if you think you can fumble your way through it, you will end up with a mess. The difference between a good house and an average house is in the small details. It starts with a good plan and ends with the little details put together so the house turns out looking like it was done professionally. You would be wise to hire a good general contractor. In a lot of cases, he will save you money on the trades and save you a lot of grief in headaches.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-01-2010, 09:55 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated, there is a specific process to standing a wall like that. Fully assembled with plywood and headers, its a very heavy wall. It involves as many as 6 + people (inexperienced= add more people), to avoid racking the wall, pre-attached plywood with strong-backs, tall step ladders, pre-attachment of end & middle - support "legs", possibly leaving the headers out and installing after (weight reduction), and specific toe-nailing of the bottom plate (as hinges and to secure it during raising).
As suggested, you are better off having it done professionally, as the chances of a rookie doing it wrong, and ending up with a pile of wood and injuries, or with nails pulling apart, wall out of square and plumb, warped, etc = are very high.
- Build Well -
Old 02-01-2010, 11:48 AM   #7
Love for Construction
<*(((><'s Avatar
20' tall, ummmm....I would second ScubaDave's suggestion of a crane. If I were you I would look into either building the wall in place, or hiring out for that particular section of the framing.
<*(((>< is offline   Reply With Quote
Old 02-01-2010, 11:57 AM   #8
Sounds like you are doing balloon framing,
Why not build platform framing instead ?
Much easier & the way I built my addition - 3 stories including the garage & walk up attic
Old 02-01-2010, 08:54 PM   #9
a Lull would be my suggestion. I have lifted a wall 80+ feet by 16' tall. That included 2 lulls, 4 jacks and about 10 guys all trained carpenters. Good luck bud.
Why not just section it up?
wnabcptrNH is offline   Reply With Quote
Old 02-01-2010, 10:26 PM   #10
jlhaslip's Avatar
Rewards Points: 396
Scuba,
I have seen walls that needed to be two stories tall in a typically platform framed house to accommodate the openings according to the designer.
The OP needs to consider getting a crane and experienced help.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-02-2010, 12:52 AM   #11
Build the wall in place. These guys are trying to scare you . It is not that hard. I built my first house with no experience at all. I had no idea what I was doing. Bought a few books. Framed it, did the electric, plumbed it, sheet rocked it, trimmed it, tiled it, sided it on and on. I still come here for advice because I need to learn a lot more. But if you have the desire and will, you can do it. Maybe not the best way the first time but how else are you going to learn. Most of us are not lucky enough to study under someone who knows everything. We have to stumble before we can walk.
warnerww is offline   Reply With Quote
Old 02-02-2010, 01:09 AM   #12
jlhaslip's Avatar
Rewards Points: 396
Hope nobody gets hurt real bad...
Old 02-02-2010, 01:13 AM   #13
Build it in place. Do not have to stand up wall. Do not get hurt. With a little bit of common sense.
Old 02-02-2010, 01:40 AM   #14
jlhaslip's Avatar
Rewards Points: 396
They would be working on 3 lifts of scaffolding, possibly 4 depending on the site.
That might be difficult for a first timer as well.
The crane cost would likely be cheaper than buying or renting scaffolds.
A wall of that size is nothing to play with, imho, and I've done a few just like it.
Old 02-02-2010, 02:14 AM   #15
Could be done with no scaffolding. Depends on what you can build. Inside the structure. Come on did they rent scaffolds a 100 years ago. Oh yea they built them. I think the guy needs to think about it but by no means is it beyond even a first timer. Easy ? NO. But I do understand trying to do something safely on a Budget. For some people time is a lot cheaper than spending money ( for others time is very important). The funny thing is this guy probably is not even reading this now. We are just disagreeing (Which is kind of fun).
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
