How To Square A Room? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 03:25 AM   #1
Rewards Points: 150
Exclamation
How to square a room?
Ok so I know to find out if my room is square or not. Use the 3,4,5 method or the 6,8,10 method if you have a larger room. I'm off by 1/2" give or take, it's really close. So now, how do I square this corner for framing?
Mijotter is offline   Reply With Quote
Old 03-06-2013, 06:00 AM   #2
Rewards Points: 150
Do you really need to. If so pack out strips from 1/2 in .to nothing
kaschmid3 is offline   Reply With Quote
Old 03-06-2013, 06:57 AM   #3
Rewards Points: 12,858
Need more info on exatly what it is your trying to do.
Are you trying to build a single wall, a new room, is this something your trying to build in the basement, how big.
If it's a whole room with 4 inside corners just measure from inside to inside corner.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
oh'mike (03-06-2013), woodworkbykirk (03-06-2013)
Old 03-06-2013, 02:01 PM   #4
Rewards Points: 150
I'm building a room within a room in part of my basement for a theater room. The room is 17' 7" x 11' 8".
And I don't know if I really need to, should I only being off that much for framing?
Old 03-06-2013, 02:05 PM   #5
Any reason for those old ball sizes? That's going to make the whole room harder to frame and sheetrock.
Old 03-06-2013, 02:10 PM   #6
Rewards Points: 150
That's the dimensions of the room. nothing I can do about that. That's the dimensions before the framing too.
Old 03-06-2013, 02:25 PM   #7
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Mijotter View Post
...so I know to find out if my room is square or not.
If the 3/4/5 indicates a problem... then start with a simple distance measurement between points on the North wall and corresponding points on the South wall. If it is masonry construction I doubt it'll be out by much.
Old 03-06-2013, 02:30 PM   #8
Rewards Points: 150
There are 2 exterior cement block walls that I covered and glued 2" xps board to. That's where I did my 3,4,5 measurement from.
Old 03-06-2013, 03:17 PM   #9
"You can do anything"-Mom
brockmiera's Avatar
Have you framed any of your walls yet? I just framed my basement and NONE of my exterior concrete walls were square with one another. I had to frame the new walls square with respect to each other but they were not tight up against the exterior walls.
brockmiera is offline   Reply With Quote
Old 03-06-2013, 03:33 PM   #10
Rewards Points: 150
No I have not done any of the interior framing as of yet. How would I go about squaring the interior walls?
Old 03-06-2013, 03:41 PM   #11
brockmiera's Avatar
I used a chalk line and your 3-4-5 rule to lay out my walls. Then I double checked square by measuring the diagonals. It took a little time to get it right because I didn't realize my concrete walls were out of square.
You already know they are out so in your case depending on which wall is skew, I'd measure 4" out from your xps on one end, 3.5" out from xps on the other end and snap your line. Then go off of that chalk line as your reference wall. I dont have a drawing, picture, sketch or anything of your specific situation else I could work the math for you and give you better directions.
Old 03-06-2013, 03:45 PM   #12
Rewards Points: 150
I have a very crude outline of the room here;
Old 03-06-2013, 03:57 PM   #13
brockmiera's Avatar
Well keep in mind im not a framer, Just a DIY guy with good math and problem solving background. With that said.
1) I would start in an exterior corner and measure 3.5" from each wall and put a dot.
2) Then go to the furtherst length of your wall and measure out 3.5" put a dot
3) then do the same along the other wall.
4) Using an equation developed by Mr. Pythagoras figure out what your distance from 2 to 3 should be.
If your actual measurement is less than what it should be then you know your corner is > 90* and you can adjust your points 2 and 3 equal amounts or move whichever makes the most sense with the rest of your framing.
If your actual measurement is more than what it should be then you know your corner is <90* and you can adjust the corner out into the center of the room until the math works.
Keep in mind that if you are out of square to start things will multiply the further you get away from your reference point.
I hope this helps.
Tags
basement , framing , square , stud , wall
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
Soundproofing a basement room MrAngles Insulation 5 06-06-2012 10:01 PM
How big should a mechanical/utility room be? reveriereptile Building & Construction 30 03-14-2012 09:11 AM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
