How To Span Dance Floor Without Support Columns - Building & Construction - DIY Chatroom Home Improvement Forum
Closed Thread
Old 11-24-2009, 01:12 PM   #1
Question
how to span dance floor without support columns
How would I span a dance floor roof, flat concrete roof without using support columns, just load bearing walls. the room size is 104'X70'. I thought of using steel i beams in the longest lenght 104' then using 2x10 wood joists to connect to i beams. or use steel web joists. If I use steel web joists what spacing do I use?
mark4teach is offline
Old 11-24-2009, 01:14 PM   #2
Wink
steel beam
This is for a student in my class who is designing a dance floor. I want him to be as accurate as possible.
Old 11-24-2009, 01:23 PM   #3
Licensed Engineer
Rewards Points: 175
Bar Joists in the 70 ft dimension
Even 70 feet is a loonngg span. Investigate using the style of bar joists with bolts welded to the top chord which get encased in the concrete roof deck when it is poured. I think these are called bulbs, but I might be wrong.
MI-Roger is offline
Old 11-24-2009, 01:25 PM   #4
This WAY beyond DIY, which is what this site is for
Consult with a Pro
Thank you
Scuba_Dave is offline
Closed Thread
Tags
i beam span , steel web joist spacing
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
How to add another support beam under floor joists LOStouten Carpentry 3 11-13-2008 10:55 PM
Adding support to "springy" floors-this mom's got to do it herself! LOStouten Building & Construction 10 11-12-2008 08:38 PM
Maximum span without intermediate support question yaryar Building & Construction 2 11-11-2008 10:08 PM
