-   -   how to span dance floor without support columns (http://www.diychatroom.com/f19/how-span-dance-floor-without-support-columns-57890/)
mark4teach 11-24-2009 01:12 PM
How would I span a dance floor roof, flat concrete roof without using support columns, just load bearing walls. the room size is 104'X70'. I thought of using steel i beams in the longest lenght 104' then using 2x10 wood joists to connect to i beams. or use steel web joists. If I use steel web joists what spacing do I use?
mark4teach 11-24-2009 01:14 PM
steel beam
This is for a student in my class who is designing a dance floor. I want him to be as accurate as possible.
MI-Roger 11-24-2009 01:23 PM
Bar Joists in the 70 ft dimension
Even 70 feet is a loonngg span. Investigate using the style of bar joists with bolts welded to the top chord which get encased in the concrete roof deck when it is poured. I think these are called bulbs, but I might be wrong.
Scuba_Dave 11-24-2009 01:25 PM
This WAY beyond DIY, which is what this site is for
Consult with a Pro
Thank you
