Old 11-15-2012, 11:28 PM   #1
Rosemarys's Avatar
How to smooth out cement/concrete walls
The house I'm purchasing has this cement texture like walls that I would like to smooth out. If I could do this myself, what do I need? For a 10 by 10 room, how much would this cost me? Should I hire a skilled person instead?
Rosemarys is offline   Reply With Quote
Old 11-16-2012, 12:57 AM   #2
Got a picture.
Sure your not talking about sheetrock walls that were textured?
Not sure what concrete like walls even means.
Could be pored concrete, concrete blocks, plaster ECT.
Old 11-16-2012, 01:12 AM   #3
Rosemarys's Avatar
Here's a photo. I was aiming for the popcorn ceiling that I will discuss later but you can see the side wall. Unsure what it is
How to smooth out cement/concrete walls-image.jpg
Old 11-16-2012, 01:25 AM   #4
Looks like popcorn texture on the ceiling and knockdown texture on the walls.
http://www.bing.com/images/search?q=...ture&FORM=IGRE
Need to really know what's under it, drywall or is this a concrete building.
Old 11-16-2012, 01:44 AM   #5
Rosemarys's Avatar
I'll have to go back and scrape it off and see what's underneath. I'm researching in advance since I would like to get an idea of how much I will be spending with ceilings, walls, paint, flooring, etc.
Thanks for the respond. I will update ASAP.
Old 11-16-2012, 01:46 AM   #6
Thats what it is
epson is offline   Reply With Quote
Tags
#resurface, #wall
Priming / Painting smooth walls beachfront71 Painting 21 06-27-2012 06:46 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
