How To Smooth A Basement Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 09:30 AM   #1
how to smooth a basement floor?
I have an older basement floor that is rough. How do I put a smooth surface over the older rough floor?
Victor Wagner is offline   Reply With Quote
Old 06-04-2010, 09:54 AM   #2
Rewards Points: 1,016
Rough as in has a broom finish?
Rough as in has chunks missing and is broken?
Rough as in the surface is scaling?
Pretty level or not?
Pictures would help.
Old 06-04-2010, 06:28 PM   #3
I have a similar problem and found that you can buy floor leveler. It comes in a dry powder form (like cement) and is mixed with water.
I'm hoping to level off my floor with this product.
Old 06-05-2010, 07:16 AM   #4
Rewards Points: 4,534
we use polymer-modified cement w/fine aggregate NOT avail at any apron store,,, look to a pro const supply house instead,,, floor levelers do not usually have the abrasion resistance OR compressive strength necessary for resurfacing on their own,,, proper PREP is the key - that + reading AND understanding the directions
The Following User Says Thank You to stadry For This Useful Post:
Wildie (06-05-2010)
Old 06-05-2010, 01:09 PM   #5
If applicable you can rent a machine with grinding stones attached, ( like a floor polisher ) It will grind off high spots, and can give the cement a cut stone appearance if it is done long enough. It can be a dusty job, so wet down the surface first.
BruceW is offline   Reply With Quote
Old 06-08-2010, 02:45 PM   #6
some rental yards will have edco grinders - 6 diamond inserts held on w/oak wedges not aware of anyone renting pro stuff to h/o-diy'ers,,, impo, edco's a decent machine but we own other brands,,, btw, nothing's dusty IF you have the right vac hooked up properly
Old 06-08-2010, 06:51 PM   #7
Rewards Points: 502
if its just a rough texture, I'd paint.
forresth is offline   Reply With Quote
Old 06-08-2010, 09:11 PM   #8
thought everyone knew, by now, there's no paint that'll adhere to conc 'cept temporarily,,, then its a pita to remove & resurface
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Wet basement floor Saiboogu Building & Construction 9 08-12-2009 06:19 PM
Paint(?) on basement floor dissolves with water Jaybone Painting 3 08-26-2008 12:51 AM
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 06:23 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
