-   -   how to smooth a basement floor? (http://www.diychatroom.com/f19/how-smooth-basement-floor-72791/)
Victor Wagner 06-04-2010 09:30 AM
I have an older basement floor that is rough. How do I put a smooth surface over the older rough floor?
vsheetz 06-04-2010 09:54 AM
Rough as in has a broom finish?
Rough as in has chunks missing and is broken?
Rough as in the surface is scaling?
Pretty level or not?
Pictures would help.
Wildie 06-04-2010 06:28 PM
I have a similar problem and found that you can buy floor leveler. It comes in a dry powder form (like cement) and is mixed with water.
I'm hoping to level off my floor with this product. :yes:
stadry 06-05-2010 07:16 AM
we use polymer-modified cement w/fine aggregate NOT avail at any apron store,,, look to a pro const supply house instead,,, floor levelers do not usually have the abrasion resistance OR compressive strength necessary for resurfacing on their own,,, proper PREP is the key - that + reading AND understanding the directions :thumbsup:
BruceW 06-05-2010 01:09 PM
If applicable you can rent a machine with grinding stones attached, ( like a floor polisher ) It will grind off high spots, and can give the cement a cut stone appearance if it is done long enough. It can be a dusty job, so wet down the surface first.
stadry 06-08-2010 02:45 PM
some rental yards will have edco grinders - 6 diamond inserts held on w/oak wedges :yes: not aware of anyone renting pro stuff to h/o-diy'ers,,, impo, edco's a decent machine but we own other brands,,, btw, nothing's dusty IF you have the right vac hooked up properly :laughing:
forresth 06-08-2010 06:51 PM
if its just a rough texture, I'd paint.
stadry 06-08-2010 09:11 PM
thought everyone knew, by now, there's no paint that'll adhere to conc 'cept temporarily,,, then its a pita to remove & resurface :furious:
