How To Size Steel Cable For Barn Wall Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 08:00 PM   #1
Rewards Points: 89
How to size steel cable for barn wall repair
Does anyone have any experience with jacking a barn roof/pulling the top plates in?
I'm researching the project and I haven't found any discussions about what size cable to use. I'd have no idea how much force it will take to bring the plates back in before repairing the broken mortises.
My instinct is to get the biggest I can (afford).I see 3/8" typically supports 14,400 LBS. Considering the barn's only 23'x23' and I'll be using 3 cables, I assume that's way overkill.
I guess I'd love to find someone that's actually done something like this and can speak from experience.
Thank you!
tbeaulieu is offline   Reply With Quote
Old 03-30-2011, 10:44 PM   #2
Rewards Points: 282
probably not a diy job.
you could end up with a dynamic load and be in a bad situation. dynamic load could occur if the wind blows the wrong way for instance.
i would either get a pro to raise and crib it until repair is done, then lower it, OR re-engineer in place with new structural member/supports where needed.
jcrack_corn is offline   Reply With Quote
Old 03-31-2011, 05:14 AM   #3
Rewards Points: 89
Wind? Not an issue.
Old 03-31-2011, 05:53 AM   #4
Rewards Points: 89
Yes, I'm aware of that issue and it's is not my plan. Rather, steel plates and eye bolts are.
Your wording sounds almost verbatim to RIchard Lazarus' writeup.
Thank you.
Old 03-31-2011, 10:31 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... You'll need cabling that equals the strength of whatever yer doin' the pulling with...
A 2 ton come-a-long needs atleast 2 ton cabling...
Bondo is online now   Reply With Quote
Old 03-31-2011, 10:35 AM   #6
Rewards Points: 89
The real question isn't how strong does each of the indiviudal components need to be, but rather the cable strength. Everything will depend on that.
Probably won't even be using a come-a-long.
If I had done this before I'd have an idea as to the effort required and satisfaction with the cable used. I'm hoping someone's done this before and can speak to that experience.
Thank you.
Old 04-04-2011, 09:06 AM   #7
Rewards Points: 89
I found a good writeup of someone correcting a bow from an almost identical setup as mine using tow straps instead of cable. Sounds good to me.
Old 04-04-2011, 09:31 AM   #8
Concrete & Masonry
Rewards Points: 576
I can honestly say I have no first-hand experience doing this personally, but we had worked with a pro who straightened barns for a living for many years. As I recall, he always used 1/2" cable. I know he didn't buy it, so that could be why he chose to use such a big cable. He had some connection that got him as much free/cheap cable as he wanted, as it came from a skyscraper's routine elevator maintenance.
jomama45 is online now   Reply With Quote
Old 04-04-2011, 09:38 AM   #9
Rewards Points: 89
That's an interesting source!
Thanks for mentioning the 1/2". It's the first concrete sizing I've heard.
I started looking into the straps. Not surprisingly, mfg claimed capacities are no where near their working capacities, so I need to research this a bit more. I plan to use straps; one to each side of the main beams that connect the walls to the center post.
At some point, someone installed rods to hold the walls to the beams, but it split anyway and bent the eyelets in the beams. I suspect they were installed to stop the spreading, which had already begun.
The more I read on this, the less mysterious and scary it becomes.
Old 04-04-2011, 09:44 AM   #10
Concrete & Masonry
Rewards Points: 576
It's not near as scary as some may believe. I think the most intimidating part of the whole project would stem from one's fear of heights, if that was your own case. The one thing I can caution on is don't get "greedy" in moving, pulling, or straightening of the barn's structure. It took decades for it to shift, don't try to return it to it's original state in a few days, or you'll certainly be pushing the limits of your hardware, not to mention your own safety & luck..........
Old 04-04-2011, 10:03 AM   #11
Rewards Points: 89
You're right. I have no idea how long it will take to bring it back in. My neighbor is super smart about this stuff and he's done it before on his own home. In his project he let the wood "talk to him". Each morning he'd give everything a little crank until he met resistance and then stopped.
I could end up lucky and have it go really easily if my suspicions are correct in that the rod was inserted in recent history, as opposed to 100 years ago.
While heights has been a major challenge for me, I'm making progress. In this project, however, I have a loft in the barn, so most of the work will be real easy in that respect. I think I'm going to install steel plates on the outside of the beams (two per side, in addition to the one that's already in the middle) with threaded eye bolts. That will probably be the only work done on a ladder.
Old 04-04-2011, 10:08 AM   #12
Concrete & Masonry
Rewards Points: 576
One more thing I just remembered from years back was that he always used 18-24" sections of channel iron on the backsides of his posts for pulling. Not sure if it was critical, or if was just material that he had lying around.
The Following User Says Thank You to jomama45 For This Useful Post:
kwikfishron (04-04-2011)
Old 04-04-2011, 11:08 AM   #13
kwikfishron's Avatar
Rewards Points: 594
on the channel
theaulieu, can you post a picture or two of your crooked old barn?
kwikfishron is online now   Reply With Quote
Old 04-04-2011, 11:25 AM   #14
Rewards Points: 89
"crooked old barn" ... boy, that sure makes it sound crummy!
Old 04-04-2011, 11:40 AM   #15
Rewards Points: 594
Nice shot of the tenon pulling out.
I was hoping to see a stand back shot of the whole thing to get a visual of what your up against.
Tags
barn , steel cable , walls spreading
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 06:05 PM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 06:19 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
