How To Sister I Joist - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 12:50 AM   #16
DIY or die !
Rewards Points: 77
You my friend need to install some POSTS. thats a BIG aquarium....alot of added weight on your floor joists. I would much rather see that weight be transferred to the basement underneath. personally I would rather OVERdo it on this one...
lewisthepilgrim is offline   Reply With Quote
Old 12-31-2012, 06:52 AM   #17
Thank you all for the responses. I think I will rather over do it on this one, especially since this is my first home and first real DIY project. So my plan based of of everyone suggestions is to sister the two i-joists below the aquarium as mentioned in the earlier replies. Then I will use the two jack posts I have and place them underneath the joist that is directly under the aquarium for added support and to transfer the weight to the basement floor. I already had purchased two jack posts and a 4x6. Would that be enough to transfer the weight down to the floor? Like I mentioned the aquarium will be about 8 inches from a load bearing wall and will be over one i-joist and 3/4 of the way to the second joist. Is there an approved method to transfer some of the weight to the second i-joist or would the sistering and then using the 4x6 and two jack posts suffice for this application? I will purchase the rest of the items needed this week so I can work on it over the coming weekend. Thanks again for helping me make this project work.
datahoe is offline   Reply With Quote
Old 12-31-2012, 07:32 AM   #18
Devil Dog
handyman_20772's Avatar
Rewards Points: 77
You will probably need to dig and pour concrete for footers under those jack posts to properly transfer the load to the foundation of your house. This may may be required in your area...check with your local building dept. or a structural engineer.
handyman_20772 is offline   Reply With Quote
Old 12-31-2012, 07:53 AM   #19
also consider upgrades in is tank size later...but look at it this way. If you frame a little room under you could add a sump /filtration etc to run underneath adding capacity ...
Sean'o ATHS is offline   Reply With Quote
Sister Joist - Notch Question pleasedrivefast Building & Construction 8 06-01-2012 08:50 AM
Widening gap - notch sister joist or cinder block? John_W Building & Construction 6 06-29-2011 09:37 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
sister a joist Jack Hass Carpentry 7 06-19-2007 06:39 PM
