How to Sister I Joist
Hello,
I'm new to DIY and looking for a little advice. I am placing a 175 gallon aquarium in my living room and need to reinforce the floor it will be. Below the living room is unfinished and I have access to the floor joists ( I joists that are 24 inch on center). The aquarium will have to go parallel with two joists along a load bearing wall. Others have recommended I sister the two I joists with 2x12 and I should be fine. Would screwing or nailing a 2x12 into the I joist compromise the joist? What would be the best and most cost effective way to reinforce the floor for an aquarium? The house was built in September 2012. Any advice or information would be greatly appreciated. I just don't want to do something that can affect my new home, in a negative way. |
That would work if it can fit in the webbing of the joist.
Georgia Pacific suggest just using 3/4 plywood or OSB on both sides with constrution adhesive and nails. |
for extra strength fill in between the top and bottom chord with plywood then sister along the full width of it with plywood as well. do it so its glued and screwed but when you fill between the chords maks sure you dont cut it so its deadly tight leave 1/8 - 3/16 gap as if you cut it tight you can spread the joist apart which desroys its integrity
exactly what woodworkbykirk mentioned except don't forget to stagger the plywood seams away from each other as far as possible. staggered seams will help make the span stronger
Thanks for the advice. Just so that I am clear, when you say "fill in between the top and bottom chord with plywood" you cutting plywood and screwing/nailing it to the webbing with adhesive? And to "sister along the full width as well" you mean add an additional piece of plywood on the outside screwing/nailing it to the top and bottom flange? Sorry for the questions but I want to make sure I do this right for this and future projects since this is my first real DIY project.
Thanks hand drive, I'm not sure what is meant by staggering the plywood seems. Can you clarify for me? Thanks again
Staggering the plywood means to offset the plywood seams on each side of the joist. Plywood comes in 8' lengths, so you will have a splice on each side.
Thanks sixeightten....now it makes sense!
if you have a 10' span, an 8' piece of ply would be used with a 2' piece to finish it out.v next over lap the opposite direction putting the seam on the opposite side. then cut ply to go over those that is wide enough to cover the full width of the joist bottom cord to top cord...
most i joists have a 1" gap betwwen the web and the chords so i take 2 layers of 1/2" ply to fill it.. first starting with a 8' peice centered then fill in the ends. then for the 2nd layer just switch it.. start from the end then finish. then a layer of either 1/2" or 3/4 on the outside
Depends on the brand for the thickness of ply fillers. Some I's are rated at 1500#, others ? Offset nail the fasteners into the top/bottom chord as well, C-3; F-11 if sistering another I-joist. https://docs.google.com/viewer?a=v&q...GHwNIkSbvrbL_A
I would not use a new solid wood joist as a sister in your case. Gary |
175 gallons equals 1457.75 lbs. With my background in construction and structure engineering, I would recommend considering seriously building a weight bearing framed wall directly underneath the aquarium to permenantly transfer the weight from the floor joists to the concrete slab of your basement. Otherwise, you will dent your floor joist system in that very spot, causing unwanted problems down the road. Hope this helps. |
Thanks all for your replies! I am beginning to gather a way to proceed with this project
| All times are GMT -4. The time now is 05:51 PM. |
