How Should I Flash This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 07:21 AM   #1
Rewards Points: 156
How should I flash this?
I'm hoping that the pics below give you an idea what I'm dealing with.
I have a back patio that I plan on tiling. I applied 2 coats of redgard over the cement board to waterproof it (see pic). I am installing ceramic tile over the redgard.
Over the sides of the patio there will be siding (the 2nd pic is older but should give you an idea of what I'm working with, the patio is above the garage door on the right). Wondering how I should flash over the edges to transition from the tile to the siding.
I borrowed a brake, so can make custom bends to do this. Any help is appreciated
Branden is offline   Reply With Quote
Old 07-27-2010, 07:29 AM   #2
Rewards Points: 156
Here is another picture. Again, it is older and a lot of work has been done since it has been taken, but to give you another idea of what I'm looking at. Realize that all of the wood has been replaced since this was taken and everything is properly sloped and structurally sound. I also am building some steps to come down the side.
Thinking maybe I should bend a 90 out of aluminum coil stock and put it from under the tile to over the plywood. Butt my j-channel up flush with the tile and caulk the joint? I dunno, just an idea.
Old 07-27-2010, 02:24 PM   #3
kwikfishron's Avatar
Rewards Points: 576
Absolutely flash it. I’d bend some 90 degree stock, at least 3”on the deck and 1 ” down the wall over the siding with a hem and a drip edge on the wall side.
It would be better if the siding was up, if not figure out how your siding is going to end up at that spot so you know how far to overhang the flashing so the flashing over siding will be a clean snug fit.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Branden (07-27-2010)
Old 07-27-2010, 02:29 PM   #4
Rewards Points: 156
So I should lay the tile first and flash from over the tile to over the siding?
If so, how should I fasten the flashing to the tile?
Maybe go from under the tile to over the siding with silicone caulk where the flashing meets the tile?
Old 07-27-2010, 02:42 PM   #5
Rewards Points: 576
You want the flashing under the tile and over the siding.
Branden (07-29-2010)
What is a flash player rustyebor PC Repairs & Upgrades 6 12-28-2009 02:35 PM
American Standard Furnace-2 flash flocke HVAC 2 12-10-2009 09:16 AM
Arc Flash ctsmiths Electrical 53 01-27-2009 05:57 PM
Comfortmaker RPJ - 1 Flash - Nothing ON olgranddad HVAC 29 01-02-2007 09:23 PM
