How Shallow Can I Make This Pitch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2015, 01:58 AM   #1
Rewards Points: 36
How Shallow can I make this pitch
I live in Michigan.
I would like to run the drain pipe in the attached pic farther out into the backyard. I understand the typical elbow, to the right of the picture, is 30 degrees. I found flex elbow at the big box. How shallow can I set the flex elbow so that water does not freez too quickly in the winter before it can be discharged? Is 10 degrees too shallow?
(I am constrained by what I can do above the elbow shown in the pic.)
gettingthisdone is offline   Reply With Quote
Old 07-11-2015, 08:10 AM   #2
Rewards Points: 236
wth is that ? is there a walk there ?
Fix'n it is offline   Reply With Quote
Old 07-11-2015, 08:14 AM   #3
craig11152's Avatar
Rewards Points: 240
I live in Ann Arbor MI....you lost me at "..... so that water does not freeze too quickly in the winter" No matter what you do your at the mercy of mother nature...how cold it gets, how fast it gets cold and how long it stays cold. Having lived in SE Michigan since 1961 its a rare winter that gutters and downspouts are functioning in January and February
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following 2 Users Say Thank You to craig11152 For This Useful Post:
gettingthisdone (07-11-2015), Yodaman (07-11-2015)
Old 07-11-2015, 10:24 AM   #4
Rewards Points: 5,336
Why don't you take that erector set down and run the pipe underground to a low spot on the property or a drywell?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 07-11-2015, 10:38 AM   #5
craig11152's Avatar
Rewards Points: 240
A drywell could be problematic in SE Michigan. We have a lot of clay soil. In some places its very heavy.
The Following User Says Thank You to craig11152 For This Useful Post:
Old 07-11-2015, 01:09 PM   #6
Rewards Points: 13,712
That goofy set up is never going to work, and looks like poop.
Old 07-11-2015, 01:34 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you use heat trace cable you can run your slope as slow as you want to.
The Following 2 Users Say Thank You to nap For This Useful Post:
gettingthisdone (07-11-2015), oh'mike (07-11-2015)
Old 07-11-2015, 03:04 PM   #8
Rewards Points: 3,837
Drain pipes work quite well at 1/4" per foot run. @ 1/2" they drain even quicker. @ 1/8" they are a little slow.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Old 07-11-2015, 03:14 PM   #9
The soil content is irrelevant to the underground design. You just modify it. Set up a few drywells (if you want) at the back of the property. On top of each drywell you install a popup. If the drywells fill up, the pop up releases the water at the back of the property.
And that's the goal, right? Get it away from the house.
To make sure it drains properly all year round you install ice melt cables in the gutters and the underground pipes all the way to the drywells.
Ron
B. Franklin 1759
Old 07-11-2015, 03:39 PM   #10
craig11152's Avatar
Rewards Points: 240
Soil content is relevant thats why you just said modify and add. because the soil content is relevant. If it wasn't relevant you wouldn't modify.
Old 07-11-2015, 03:50 PM   #11
Rewards Points: 582
i don't care where you live...you can not and should not do what you are doing ...its just wrong ,...oh and did i say it looks like sh#$@$#it...think about it you can do better,,,
Old 07-11-2015, 04:29 PM   #12
Rewards Points: 36
Thanks guys.
1. As Ron6519 points out, the aim is to move the water away from the basement.
2. Having moved the water away from the basement, I was thinking of adding a rain garden further in the back. That's the reason for wanting to move it farther out.
3. About it looking ugly .... getting the water away from the basement at the cheapest cost possible is my absolute priority. I did not intend to leave the fittings like that -- I will be painting them also. (I used rustoleum spray paint, but now I am thinking I will just brush paint it and try to get a better custom match with the fence.
4. @ben's plumbing , could you tell me why it is wrong? Is there a code violation? BTW, I asked the neighbor if he was ok with it, and he says he has no problem with it.
5. Thanks for the info about the drywells. I will certainly consider in the future, but with many other things on my plate now, that is not a priority. But thanks for making me more aware of its possibilities.
Thanks!
Old 07-11-2015, 04:30 PM   #13
Rewards Points: 36
Forgot to say thanks Nap. I did not know that those heater things existed. Will certainly consider as I balance costs and function moving forward.
Old 07-11-2015, 05:36 PM   #14
DIY staff
Rewards Points: 7,174
The heat cable/tape work well and can be on a switch so you can turn it on when needed.
Old 07-11-2015, 05:42 PM   #15
They actually now have a sensor that will not turn the power on unless:
1. The temperature is below freezing
and
2. There is moisture present.
You can leave the switch on and let the sensor control whether it's activated.
This is an option when you buy the cables.
Ron
B. Franklin 1759
Tags
drain pipe , winter
Best material for a 3:12 pitch roof extension? Nittany Roofing/Siding 7 05-31-2012 02:34 PM
GAF stormguard for low pitch roofs Dave K Roofing/Siding 2 05-11-2011 05:39 AM
best way to make a small water tank? Red Squirrel Plumbing 22 05-01-2011 06:12 AM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
