How To Secure Bottom Of 4 X 4 Post To Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 10:22 PM   #1
Rewards Points: 682
How to secure bottom of 4 X 4 post to concrete?
I have a subroof covering the walkway to the front door of our house. It is supported by four 4X4 posts, about 8' or 9' high.
One post had to be removed because of dry rot and termite damage. When I removed it it did not seemed attached to the concrete walkway at all.
How does one attached a post to a concrete walkway? I have experience with attaching wood to wood, but none with wood to concrete. I don't think the attachment has to be very strong.
darsunt is offline   Reply With Quote
Old 08-18-2009, 05:41 AM   #2
Rewards Points: 1,016
Usually a bracket is used - rotary/hammer drill the concrete for an expansion bolt to anchor the bracket.
Example (notice it spaces the wood from direct contact with the concrete and to keep the post from sitting in water)
http://www.strongtie.com/products/co...ba-abe-abu.asp
Old 08-18-2009, 08:40 AM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
I would hope that the columns are attached to footings. My humble opinion, but the guy that installed a 4x4 support column and set it to rest on a side walk basically jury rigged it. Anchoring it to the side walk is better than what was there, but it's still wrong to me without a footing. Maybe I'm missing something. Can you post a pic?
Aggie67 is offline   Reply With Quote
Old 08-18-2009, 10:53 PM   #4
Rewards Points: 682
I am not sure what a footing is, but the post just sits on top of the concrete walkway that goes to the front door. I assumed it would be fastened to the concrete in some way and was surprised when the whole post just came off.
All of the posts are that way. They don't support the main roof, they support a separate 4' X 15' separate roof that just covers the walkway. The subroof probably has rafters that extend into the framing of the house, the posts support the outer edge of the roof. I doubt any of the bottom of the posts are attached to the concrete by anything except gravity.
I will look into that bracket idea. Thanks.
Old 08-19-2009, 06:34 PM   #5
Rewards Points: 682
By the way, today I found out the workers who assembled this part of the house used a nail gun to attempt to shoot nails thru the base of the posts into the concrete. The nails did not penetrate much into the concrete, of course, but maybe they penetrated just enough to make the posts stay in place.
Old 08-19-2009, 07:07 PM   #6
Aggie67's Avatar
Rewards Points: 826
Toe nailing a structural post into a concrete sidewalk. Either we're missing some info, or that got slapped together. Is there any way you can post pics? I'd love to see what's going on there. What state are you in?
Old 08-19-2009, 07:36 PM   #7
Rewards Points: 682
Sorry about no pics, was out there today but didn't think to take any.
Anyways the state is CA, it is a house built in the 1960's.
I just take it with a grain of salt. Most construction I've seen has some good work, some bad work, and some very bad work all mixed together.
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 08:15 AM
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 11:21 AM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
Concrete piers for post & beam foundation jpecor Building & Construction 1 08-01-2008 12:27 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
