How To Seal Openings In Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 10:03 PM   #1
Question
How to seal openings in rim joist
Hi guys. While running power to a shed, I ran my conduit out the rim joist of the house and down the foundation wall. Now I'm just trying to figure out what the best way is to seal around the conduit where it passes through my rim joist. If it makes any difference, it's actually also passing through a ledger board for my deck, which is bolted to the rim joist. Here's a pic. In its installed position, the LB fitting in the picture is pushed flush against the ledger board, so the opening around the conduit isn't as large as it appears here.
So what would be the best option for sealing around that conduit? I picked up a can of that Great Stuff fireblock expanding foam, but wasn't sure if simple silicone caulk would be a better choice, or something else I haven't thought of. Any input? Thanks!
Dan
TheCowGod is offline   Reply With Quote
Old 04-28-2012, 10:14 PM   #2
Rewards Points: 13,968
Expanding foam would end up just maiking a mess. Silicone will work fine.
TheCowGod (05-02-2012)
Old 04-29-2012, 01:40 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
spray foam on the inside to stop drafts. then try and find a trim ring for the outside
woodworkbykirk is offline   Reply With Quote
Old 05-02-2012, 09:51 AM   #4
Thanks, guys. I'll use caulk on the outside and maybe spray foam on the inside if it seems necessary.
Dan
Old 05-02-2012, 01:31 PM   #5
Rewards Points: 626
spray foam then trim back the extra that pushes out. After looking at it it is electrical fire block foam. It will out last your home.
Nailbags is offline   Reply With Quote
Old 06-24-2012, 06:42 PM   #6
Rewards Points: 242
On the inside of the house is the plastic conduit that goes thru the rim joist going into a metal junction box? If so what type of fitting did you use to transition from the plastic conduit to the metal box?
collegetry is offline   Reply With Quote
Old 06-24-2012, 07:36 PM   #7
It mates with a PVC junction box, and that's where I spliced from the THWN to the Romex 6/3, which exits the box with a romex clamp.
Dan
Old 06-24-2012, 10:59 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Get rid of the LB and mount a box on the wall instead.
The LB looks not good.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-25-2012, 07:02 AM   #9
Rewards Points: 242
Dan
Thanks and the LB looks fine.
Old 06-25-2012, 07:55 AM   #10
Rewards Points: 6,652
Use the DAP foam, not the Great stuff. DAP can be cleaned up with water if you make a mess. Just do not use it around copper piping, since the copper will react with it, when it touches the surface of the pipe.
Split floor joist scottyv81 Building & Construction 6 12-23-2010 02:42 PM
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 08:27 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 02:33 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 04:03 PM
