How To Seal One Corner Of A Deck From Moisture? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:03 AM   #1
Rewards Points: 682
How to seal one corner of a deck from moisture?
I have a deck where one corner has moisture problems, because there is drainage there and it is always in the shade. I've covered it temporarily with a piece of plywood. I don't want any moisture to get down there because it never dries out.
I've been thinking of replacing the plywood with a painted piece of sheet metal. Has anyone had this problem?
I like the sheet metal because it will lie flat and be unnoticeable. I'm wondering, however, if condensation will form under it in the morning and keep that corner damp.
darsunt is offline   Reply With Quote
Old 04-19-2011, 07:44 AM   #2
DIY staff
Rewards Points: 7,174
Why don't you post a picture? Covering wet wood with tin will speed up the rotting---Mike----
Old 04-19-2011, 08:07 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Really?
X2 with Mike
Post a pic with and without the beautiful metal work.....
tcleve4911 is offline   Reply With Quote
Old 04-19-2011, 03:47 PM   #4
Rewards Points: 682
Here it is
Old 04-19-2011, 03:49 PM   #5
Rewards Points: 682
You can see the plywood. I'm thinking about a piece of sheet metal down there to keep rain and condensation out, because it is in the shade most of the time. But I'm not sure if it will work.
Old 04-21-2011, 05:49 PM   #6
Rewards Points: 682
I guess no one has any better idea than mine, so I'll go ahead and slap on some sheet metal over that corner. I'll check it every 6 months or so to make sure rot isn't taking under it.
Old 04-22-2011, 01:05 PM   #7
mem
Rewards Points: 156
Why is there drainage there? It looks like there has been plenty of trouble there in the past. The bottom of the door casing has been replaced, probably from rot. And the threshold seems to have suffered over time as well. The only avenue the wood has to dry out is air circulation. If you cover it up it will never dry--may even be rotten by your first six month inspection.
You really need to address the source of the moisture. Figure out where the water is coming from in the first place and remedy that.
mem is offline   Reply With Quote
The Following User Says Thank You to mem For This Useful Post:
Leah Frances (04-22-2011)
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 07:32 PM
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 01:53 PM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 09:25 PM
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 09:03 PM
Can I seal a deck without cleaning it? goscottgo General DIY Discussions 10 02-03-2008 11:21 PM
