How To Seal A Leaking Foundation Crack From The Home's Exterior - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 11:35 PM   #1
How to seal a leaking foundation crack from the home's exterior
I'm going to be digging out a window well which has been leaking a little. I plan on grinding out a reverse V and patching it on the inside, but was wondering if anyone had any tips on preventative methods I could do on the outside....
brokenhammer is offline   Reply With Quote
Old 01-02-2011, 06:59 AM   #2
You are on the right track, dig out the crack, patch with hydraulic cement or similat. Then cover with a fiberglass mesh and a a base of something that does not fully harden, breathes with the wall. like silicone caulk, but not silicone caulk. Urethane caulk or similar would be better.
Old 01-02-2011, 08:03 AM   #3
ccarlisle's Avatar
Not sure what you are going to do but you say you are going to "dig out a window well" so it appears to me that if you're going to the trouble of doing that, then you might as well check on the weeping system while you're there and waterproof the wall at the same time. This should obviate the need for the treatment from the inside - but it can't hurt either.
If you can, go down as far as the french drain/weeping system and attach to it a vertical drain to a height about 6" lower than the window sill. Waterproof the wall below grade, place a steel corrugated well wall around it and backfill that with crushed stone.
Somethingalong those lines...you may not be able - to but that's what I glean from someone who says "he has a leak around a window well and is going to dig it out..."
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following User Says Thank You to ccarlisle For This Useful Post:
MBatson (01-02-2011)
Old 01-02-2011, 08:30 AM   #4
Sorry - I wasn't terrible clear:
There is an existing metal one that is shot. The foundation is also cracked underneath it and leaking... I was thinking of going with plastic/composite, as I think it would last longer and not rot, like the metal one just did....
Old 01-02-2011, 08:42 AM   #5
ccarlisle's Avatar
That's fine - whatever your code calls for, for the depth of the window. Be liberal with the trowel-on black stuff and use a dimpled membrane, power-nailed and glued onto the foundation wall.
That's = a patch - as some of the other guys will confirm; it may remove the problem, may not. But it's a good step.
Old 01-02-2011, 09:08 AM   #6
thanks for the tips!
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Paint Exterior Foundation ? hellothere123 Painting 1 08-26-2009 07:56 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Between insulation and foundation exterior walls sithappens Building & Construction 2 04-08-2008 12:05 PM
waterproofing exterior of foundation Monty Building & Construction 4 06-12-2007 10:48 PM
