How To Seal Between Stone Facade And Window Frame? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 01:55 PM   #1
Rewards Points: 93
How to seal between stone facade and window frame?
Hi, I've got a stone facade on the front of my house, and I'm noticing some gaps between the stone and the window frames. There was some previous repairs done before I got the house. Some repairs used caulk, others used mortar or hydraulic cement. What is the correct method/material to seal gaps between the wood frames and the stone?
scottyv81 is offline   Reply With Quote
Old 09-04-2011, 02:36 PM   #2
Rewards Points: 582
Burnt sand mastic is the traditional method.
http://www.masonsmortar.co.uk/site/b...and-mastic.htm
stuart45 is offline   Reply With Quote
Old 09-04-2011, 04:03 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i would recommend pulling all old caulking/mortar out and installing a properly sized foam backer rod then caulk with a high quality urethane sealant
Tom Struble is offline   Reply With Quote
Old 09-04-2011, 06:34 PM   #4
Rewards Points: 93
Thanks to both of you for your replies. I think I'll try the backer rod and urethane sealant route. I don't have any experience with mixing & applying mastic so I think I'd have to leave that up to a pro!
Installing retrofit windows inside raised facade Improvised Windows and Doors 6 06-11-2011 06:12 PM
False Window craleo Remodeling 1 11-18-2008 08:44 PM
