-   -   How to seal below concrete board sealed with RedGard (http://www.diychatroom.com/f19/how-seal-below-concrete-board-sealed-redgard-127981/)
Dshamgar 12-28-2011 06:54 PM
Hi,
I am remodeling my bathroom. I will be installing ceramic tiles in the shower stall walls, and using an Onyx shower base. I have already installed concrete board (HardiBacker) onto the studs, and plan to waterproof it with RedGard.
My question is this: since there is a 1/4" gap between the bottom of the concrete board and the lip of the shower pan, what should be done to waterproof that gap? I understand that there will be mortar there in back of the overhanging tiles, but I am concerned about water getting through the tiles and mortar.
Any advice is appreciated!
Thanks,
Dan
Bud Cline 12-28-2011 07:00 PM
Caulk.
abracaboom 12-28-2011 07:07 PM
That 1/4" gap is to keep the cement board from wicking up moisture. When you tile, spread your thin-set mortar all the way down, but set your tiles up a bit using spacers. When the mortar is cured, run a small bead of silicone to seal between the tub and the tiles.
Bud Cline 12-28-2011 07:15 PM
DO NOT use thinset in that gap.
Caulk that gap with siliconized or latex caulk and then use Redgard over the caulk. Regard will not stick to 100% silicone caulk. You DO NOT want moisture collecting in that crevice and it can if you stuff it with thinset.
Then after the tile is installed caulk that gap also. I wouldn't ramp those tiles either. There is no need for that and that would look really stupid. No reason to have those two or three tiles tilted/ramped.
shorteared 08-14-2012 10:18 AM
Hello Bud,
I know this thread is old but i hope you can reply to it.
Can I use an Acrylic latex caulk plus silicone in this same situation posted earlier or does it have to be straight latex?
Hope you can still reply to this thread
